  • June 25, 2025, 06:51:37 PM
Author Topic: Line length  (Read 3686 times)
Offline richardm
Line length
« on: October 05, 2018, 03:40:10 AM »
Well I never
Just posted on a couple facebook pages pictures and a few specifications of running gear of my new ringmaster, actually, my second.
OS FP20 9X4 apc and 62' .012 lines
Never had so much attention, do I keep posting about line length to get friends? S?P
Serious am I that far off whack cause the plane seemed to fly OK on its first test flight, early engine cut due to split clunk line but wingover, loops in and out, horizontal eight, all good tension, could whip after the engine cut.........
Is there a formula?
Richard Mc Fadden
Offline James Holford
Re: Line length
« Reply #1 on: October 05, 2018, 04:49:56 AM »
It was me that responded to your post. Wasnt intentionally trying to be rude.  Was just concerned about the motor size and prop used at that line length.
 But if you are maintaining good line tension especially with .012's being better than .015's in this setup. Keep on keeping on :)
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Jim Mynes
  • Chelsea, ME
Re: Line length
« Reply #2 on: October 05, 2018, 06:05:07 AM »
I’d like to see some discussion on the topic as well. A couple of guys I fly with hook 68 foot Spectra lines on a .15 powered Jr. Flite Streak, I tell them shorter lines are better, and they ask all the why questions.
I don’t know why, I don’t have the answers, but the Stunt community ‘hive mind’ agrees that 68’ is for bigger planes.
I only use stainless, so I have no experience with Spectra. My Ringmaster gets 58’ lines, .40 sized planes get 60’ lines, and I’m just starting to dip my toe into larger planes on 64’ lines. I believe that’s typical, and it seems to work well, but I don’t know the physics behind it.
I have seen the light, and it’s powered by a lipo.
Re: Line length
« Reply #3 on: October 05, 2018, 07:32:01 AM »
It has been my experience that the lines need to be long enough to reach the handle. y1
Seriously, I think it is very much a function of your flying style and capabilities.  Longer lines let you fly faster and make the maneuvers larger.  You have longer flats in the squares, etc. but the trade off is more line drag producing yaw in corners, weight in the overheads and the plane is further away from you lessening your visual accuracy.  I have flown on 65' all of my life but I am planning to drop to 60' for next season.  It is the visual part for me.  I am farsighted and I could actually see more clearly at 65 than at 60 but as my age exceeded my line length that started to change and I now find the plane easier to see clearly at 60 so I am going to adapt.
I will leave it to the ones that really know what they are talking about to tell you more.
Good luck - Ken
Online Tim Wescott
Re: Line length
« Reply #4 on: October 05, 2018, 07:38:20 AM »
Well I never
Is there a formula?
I've since converted it to a carrier plane, but I have a Ringmaster that came out of the delivery room at 32 ounces, with a 20FP and an APC 9x4.  It flew great on lines that were 60' eyelet to eyelet (so, pretty close to 62' by the rulebook -- I'm not sure how you're measuring your lines).  Having the long lines let me fly it faster and open up the maneuvers, both of which (I believe) helped me to avoid the Dread Ringmaster Stall -- the plane has done some hairy octagonal loops, but it's also done some pretty nice round loops, and square maneuvers with long enough flat sections between the big soft "corners" to score decently.
I've gotten as much as 475 points with that plane in Classic, when I wasn't nearly as good a pilot as I am now.
Re: Line length
« Reply #5 on: October 05, 2018, 07:48:42 AM »
I fly my Ringmaster with a .25LA and 9x5APC on 58'. Just what im comfortable with.
Heck I fly my now 40oz Twister with .46LA on 58' lol. I know it would perform just fine on 60'. Maybe even 62'. I just like it at 58' altho I may benefit from going to 60'. Might try one day.
As long as the line tension is there and it flies fine. Fly her til she fallas apart.
Now when I move on to bigger ships Ill of course use the appropriate line length that will help the plane fly to its best capability.
Jamie Holford
Lafayette, La
AMA #1126767
Online Gary Dowler
Re: Line length
« Reply #6 on: October 05, 2018, 08:14:08 AM »
Well I never
Is there a formula?
I've been flying planes similar to the Ringmaster for a couple years now. This year I reengined with a OS 20FP and a 9-4 APC and flying on 60' .015's.  Works beautifully , though .012's might be better b
Gary
Re: Line length
« Reply #7 on: October 05, 2018, 09:00:54 AM »
Well I never
    What is the question, exactly? 60-62' lines are pretty typical for a 20FP powered model, particularly a Ringmaster, which is *grossly* overpowered with a 20FP, running correctly. We got 3.8 second laps with the engine set properly and .015x60.
     .012 makes me a bit nervous, but should be OK if they are in perfect shape. Otherwise, you can adjust the line length +-1 foot at a time and see how it works. I would not expect to want to go shorter, just because the lap times will be so fast. It sounds like it is working pretty well as it is, is there any particular issue you are trying to solve?
    In this case, you are just trying to get it in the ballpark, refinement is not a word normally used in association with Ringmasters. Getting the elevator travel and control rates right is the most critical issue in any case, you can't use very much travel at all, and the stock control system rates (to the extent you can figure out what was intended) are vastly too fast. You can handle a bit higher control rates with the 20FP than with a Fox/McCoy, etc, but it's still almost comically slow, maybe +- 3/4" at the TE of the elevator with full handle motion.
Online Gary Dowler
Re: Line length
« Reply #8 on: October 05, 2018, 10:47:01 AM »
Brett is right about the controls!  I had been trying to fly with controls that were WAY to fast! Couldn't figure why I was having such a hard time flying decently. Fought with it for 2 years thinking I was the problem. Then Mark Scarborough came with me one day and watched. He suggested a drastic slow down in my controls.  I reset things according to his suggestions and wow! What a difference!! A plane that had been hard just to keep level flight suddenly became nimble, but STABLE, plane!!  The problem I thought was all pilot error was 95% trim and control rate! Only had 18-20 degrees of elevator travel, (about the 3/4" Brett said) but this was  plenty for all basic maneuvers.
Gary
Online Tim Wescott
Re: Line length
« Reply #9 on: October 05, 2018, 10:55:52 AM »
... Only had 18-20 degrees of elevator travel, (about the 3/4" Brett said) but this was  plenty for all basic maneuvers.
That's good enough to do the pattern!  Of course, entering a serious stunt competition with a Ringmaster is kind of like showing up for a drag race with a lawn tractor, but still.
Re: Line length
« Reply #10 on: October 05, 2018, 11:30:42 AM »
  And, more to the point, adding more elevator beyond that starts hurting the turn rather than helping it. The way to set it is to start out very slow, and speed it up a little at a time, flight by flight, trying to turn as hard as you can, until is starts to stall in the corners. Then slow it back down a notch or two. That will get you all the travel the airplane can handle, without speeding it up to the point you can't fly it, or you stall it.
     People always talk about adding a "bit extra for emergencies" like it is some clever trick, but moving it further that it can tolerate is going to make the emergency worse - or create the emergency in the first place.
   Note again - this is not about "blocking" the travel of the system to limit it. Never, ever, "block" the control travel for this purpose. You *slow it down*, meaning a given amount of handle motion results in less elevator movement. Maybe a longer control horn at the elevator, a bigger ratio of the bellcrank span to the pushrod hole, or narrow the handle spacing. You are generally better off with adjusting it at the airplane end until it is close, rather than squeezing down the handle spacing, at least to start with. Use as much spacing as you can given the other limitations, and slow down the controls in the airplane. Then use the handle spacing for fine adjustment. Doing it this way reduces the effects of line compliance/"sag", which may not matter all that much on a Ringmaster, but will matter in most other cases.
Online Gary Dowler
Re: Line length
« Reply #11 on: October 05, 2018, 12:03:22 PM »
My info base on the subject continues to expand.
Gary
Offline Dane Martin
  • heli pilot BHOR
Re: Line length
« Reply #12 on: October 05, 2018, 12:08:23 PM »
I'd say, OS 20fp, APC 9x4 revved out, and back it down enough to keep it safe. 60' .015 lines.
I had 12's break, but if you're careful with them, it's not a big deal I guess. I think people would like the feeling of control difference between 12's and 15's though. Like a more solid feel.
I've asked the question about line lengths also. It kinda (kinda,in that this isn't by any means a rule to remember) boils down to, pick a known line length and trim your airplane to suit. So if you can fly all the manuevers you can fly on that set of lines, then they're correct. Until you get pretty good then experimentation yields results for things we don't know how to look for at our beginning stages.
Re: Line length
« Reply #13 on: October 05, 2018, 01:28:18 PM »
   I tell everyone to start with the 20FP/25LA with about .015x60-62', because that will be short enough to have line tension and moderate effect on the yaw angle (in case the leadouts are misplaced or not adjustable), and not too short to screw you into the ground when the engine is set correctly.
    The biggest issue, by far, is managing the speed *without* resorting to needling (or attempting to needle) the engine down excessively. FAR too many people equate "2-stroke" = "meltdown" (which it could be in some circumstances with vintage engines), and are afraid to run the engine like it needs to - medium 2-stroke in level flight.
    You can recognize them from on-line posts where they talk about 52' lines, "what happens when the wind blows!?" and "it just runs away!". "Running away" is the way it is *supposed to run*, and if you don't run it that way, you will not get the results that everybody else gets. Set the 20FP/APC 9-4 properly, on a Ringmaster, and I guarantee that wind will be the last problem you have. The wing is an inch thick and you are going 75 mph - wind is not an issue!
   To re-iterate, set the engine (20FP/9-4 APC) by peaking the needle on the ground, that is, as lean as it will go before it starts to sag, then back off richer until you get a *distinct* drop in speed, maybe 5-6 clicks. It should wind up in a medium 2-stroke in level flight, and speed up in the maneuvers. If it ever goes "over the top" lean in the maneuvers (like at the end of the flight), reset the needle 1 click richer on the next flight, until it doesn't. If it ever does more than an occasional misfire into 4, set it one click leaner on the next flight, so it never goes into a 4-stroke, or it goes "over the top" lean.
   Note that I am not giving RPM readings because I don't want you to go by RPM, go by the sound and how it works in-flight. A 20FP will usually be somewhere between 11,500-12,200 on the ground, at sea level, on 10% fuel, but that's not a goal to shoot for. Get it working, THEN tach it to see what it is doing. The "new" 25LA will be substantially faster than that to get the same level flight speed.
p.s. again, .012 lines are OK if they are in good shape - but you are flying a 30-ish ounce airplane at up to 75-80 mph, it's not going to pull like a 1/2A. If someone already has those, keep going, but be very picky about the condition of the lines and discard them if they have *any* apparent issues.
Re: Line length
« Reply #14 on: October 05, 2018, 02:06:26 PM »
Given Bretts response here... i feel like a idiot for even saying anything lol
Jamie Holford
Lafayette, La
AMA #1126767
Offline richardm
Re: Line length
« Reply #15 on: October 05, 2018, 02:21:11 PM »
Hi James all taken in good humor, we don't have a big control line community in New Zealand so discussions like these are great H^^
Richard Mc Fadden
Re: Line length
« Reply #16 on: October 05, 2018, 02:22:21 PM »
Good deal bud :).
Jamie Holford
Lafayette, La
AMA #1126767
Offline richardm
Re: Line length
« Reply #17 on: October 05, 2018, 02:42:43 PM »
I have slowed my controls right down into the range mentioned an am pleasantly surprised with how well it turns
Richard Mc Fadden
Re: Line length
« Reply #18 on: October 05, 2018, 05:52:31 PM »
   I am sorry, I had no intent to undermine what you said, in any way. Just great minds thinking alike, and one of them overthinking it.
Re: Line length
« Reply #19 on: October 05, 2018, 06:10:03 PM »
   They can turn better than most people think - mostly because of the way they had been set up in the past, it just immediately stalled any time you touched the controls.  The two primary factors are getting the controls set up properly (very slow rates) and getting a good engine with a low-pitched prop, in that order. Saving weight helps, but not nearly as important as the other two, as long as it is within reason.
    In fact, do those two things, and then it turns so good, it tends to break the wings off! Particularly if you went for the "world's lightest Ringmaster".
     If the engine quits (Veco 19bb, 20FP, 15FP, etc) in a bad position, then it turns back into a Ringmaster, and you are going to have problems. Universal Stunt Hero David Fitzgerald is noted for crashing Ringmasters (other people's, like Ted's) while hot-dogging it for the crowd, and having the engine quit. I have seen it, it won't make a 180 degree turn from inverted at 45 degrees, to upright. David's experiments also conclusively proved it turns better with half the wing gone and the engine running, than both wings intact and the engine stopped. Proof is left to the reader.
Re: Line length
« Reply #20 on: October 05, 2018, 07:02:36 PM »
Its all good buddy :)
Jamie Holford
Lafayette, La
AMA #1126767
Offline Gerald Arana
Re: Line length
« Reply #21 on: October 05, 2018, 07:18:06 PM »
Love it! LL~ LL~ LL~
Jerry
Offline richardm
Re: Line length
« Reply #22 on: October 23, 2018, 04:09:38 AM »
Hi James
With my defective old man memory I keep forgetting to ask my flying buddy to time the Ringmaster/fp20/62 foot line combo, well today was the day, 4.9's upright, 4.6 ish inverted, just dropped the tank 1/8 th of an inch, lets see. pulls hard every where, my flying buddy thinks it is the best model when the breeze gets up it just carves through it, I can throw it it through a rudimentary F2b pattern
Richard Mc Fadden
Re: Line length
« Reply #23 on: October 23, 2018, 08:31:34 PM »
Back in the day, when we flew the only combat event on .015" lines, I sometimes would put up a "wowee" flight (prior to the contest starting) on .012" lines that were a couple feet short of the legal 60' center to center. With the fastest prop/fuel combination (50% nitro), my better ST C.35 would crack off 116 mph on legal lines (no streamer), and the planes were typically 18 oz or so. Tim can do the math, but there was never a problem with the .012" lines. I'm sure there were some raised eyebrows among those bystanders with stopwatches.  ;D Steve
