  • June 25, 2025, 10:09:05 PM
Author Topic: The T-Rex is here  (Read 30735 times)
Re: The T-Rex is here
« Reply #100 on: October 12, 2009, 08:02:45 AM »
That looks so awesome, but, I doubt if it would help me.  Need to check to see if I can afford one.  Now for the so called retarded people, some of lthem are a lot smarter than I am.  It is great when you have one that can tell you when the plane is not doing what it is supposed to do.  I have lost count of how many I have helped in CL and RC.  DOC Holliday
Offline Paul Walker
« Reply #101 on: October 12, 2009, 02:40:43 PM »
Nice work Brad. It's no simple task to develop and bring a design to production and satisfy the masses.
Looks like you already have some satisfied customers.
Keep up the great work.
Paul Walker
Offline John Sunderland
« Reply #102 on: October 13, 2009, 08:50:14 AM »
Heck, John, I think we had words once...  More than a decade ago.  HAHAHAHHA!!!  We are getting old brutha!!!
I do remember my first designs.  A lot of people said, "why don't you fly so and so's design????"  Maybe my designs sucked back then.  I did not care.  I like the T-Rex...  it is superior in every way to anything I have ever done.
We be bruthas, no matter what! Yes, I am gettin old...so maybe we had one pissin contest. I caint member! Water under an old bridge. I like yer bird too! I will have one before the dust settles.  H^^
Offline Marvin Denny
« Reply #103 on: October 13, 2009, 09:59:48 AM »
  It is too big for any engine that I currently have in my arsnel or junk barrel.  I would, however like to fly one some day.  Right now I do not think I could hold  it as my hand is still really tender.
  Bigiron
marvin Denny  AMA  499
Offline Bradley Walker
    • The Urban Rifleman
« Reply #104 on: October 13, 2009, 01:36:22 PM »
Yes we be...
-George Bernard Shaw
« Reply #105 on: October 20, 2009, 11:53:38 AM »
Bob Reeves side mounted Saito version.  MEAN!!!!
« Reply #106 on: October 20, 2009, 03:17:50 PM »
Yes, obviously the typical foam wing suspended bellcrank is NOT original.
Coming up with a way to re-create such a thing in an ARF with a two piece wing is altogether another story.  Especially if the goals were:
-make sure the the bellcrank was completely installed in the inboard wing and ready to go
-AND the USER does the final gluing of the mount.
I want the USER to glue in his own bellcrank.  So, I came up with this stack ply/ply washer system that simulates the old foam wing suspension.  No easy task actually.
No doubt well thought out, Brad. The best bellcrank installation of the ARF lot for sure, one does it oneself. I'm liking it, especially the 4 stroker. It looks industrial!
Chris...
Offline Dick Pacini
« Reply #107 on: October 20, 2009, 08:55:43 PM »
I am waiting for a flight report using a Supertigre G51.
AMA 62221
Willis Swindell
« Reply #108 on: October 21, 2009, 02:10:10 PM »
We, Phil Spillman and  Willis Swindell, went out to fly Jim Welch’s T-Rex with a ST 51 today. As you can see by Phil's smile we liked the flights. There are now three new T-Rex’s ready to be built. Here is a before and after picture of mine your choice which is the before and which is the after.  LL~ LL~
Willis
Offline Elwyn Aud
    • Inferalandings Photo Page
« Reply #109 on: November 01, 2009, 04:44:47 PM »
First flight today for this one with a four stroke.
Offline jim welch
« Reply #110 on: November 01, 2009, 05:25:57 PM »
Cool...I guess thats bob's...how did it fly?looks like 2 hands on the handle...inquiring minds gotta know..Jimmy
AMA 89335
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #111 on: November 01, 2009, 06:04:16 PM »
Actually I put it together for another club member in exchange for a T-Rex ARC. Only one flight, was a bit fast 4.9 sec on 63 foot lines, need to drop the take off RPM. Also turned inside tighter than outside, easily corrected trim issues thanks to adjustable intake and controls. Sometimes you just know when you have a good one, this thing is going to be a killer.
« Reply #112 on: November 01, 2009, 06:49:51 PM »
You will find you need about 1/8 to 3/16 down elevator at neutral flap to be equal.  I find this true with nearly every design I have flown.
Well, if the TR works with the side mounted Saito and the inverted PA and pipe (both in Tulsa) then we have demonstrated both extremes of cg and mounting flexibility and functionality at one field.  My job is done here.
I highly recommend anyone using the Saito copy Bob.
Offline jim welch
« Reply #113 on: November 01, 2009, 07:33:00 PM »
Thanks for the info Bob, sure is tempting to do another with my Saito 62.The total trimming on my st51 version was a tweek of the outboard wing with the heat gun,exackly what brad said (1/8 down on the elevator) and moving the tank down 1/8 and flys perfectly.I guess i'll have to go plural and do another with the Saito 62 since I love my 4 strokes...thanks Jimmy
AMA 89335
« Reply #114 on: November 07, 2009, 07:53:51 AM »
Bob Branch E-Rex from the Amped up forum.
« Reply #115 on: November 12, 2009, 10:08:32 AM »
Amazing finish.
« Reply #116 on: November 12, 2009, 03:30:51 PM »
That looks absolutely gorgeous.  Not too gawdy and reminds mu of some of the real planes of the 40's.  Did I say I love the paint scheme.
Offline bob branch
« Reply #117 on: November 12, 2009, 04:02:34 PM »
Brad and John
thank you,
bob
Offline Richard Grogan
« Reply #118 on: November 13, 2009, 11:12:52 AM »
Very cool and unique scheme! Definitely one of a kind.  D>K
Long Live the CL Crowd!
                  AMA 85745
Offline Scott Hartford
« Reply #119 on: November 13, 2009, 01:35:51 PM »
I do believe I have a spare Saito that needs a new home! I think this plane looks neat and I will be getting one! Good job Brad! H^^
Offline Dick Pacini
« Reply #120 on: November 13, 2009, 03:28:00 PM »
Wasn't the pilot one of the Village People?  YYYYYYYYYYYYYYYYMMMMMMMCCCCA! LL~ LL~ LL~
AMA 62221
Offline bob branch
« Reply #121 on: November 13, 2009, 07:42:57 PM »
Actually , if you are a hockey fan, he is a dead ringer for the Red Wing's Todd Bertuzzi. My wife noticed it right away.... oh, she is a hockey fan.
bob
