Where you locate your wheels has a lot to do with what you need for prop clearance. This has been discussed in the threads about the 15 degrees in front of CG location for smooth landings. Even at this location, with really tall gear legs you are more apt to nose over due to the extra leverage the longer gear has. Lots of questions on here about nosing over also, both on take off and landing. I usually have what ever the model was designed for and rarely check it. I think anywhere between 1/2" to 3/4" is adequate if the model is set up and balanced correctly. If dirt, gravel and sand are a concern, there is a wonderful new invention that yiou can apply and it's called a broom! If grass is involved, they have one for that and it's called a lawn mower! Good luck to all concerned!
