  • June 29, 2025, 09:59:02 PM
Author Topic: Outstanding source for contest wood!!!  (Read 1229 times)
Offline Louis Rankin
« on: November 27, 2007, 11:23:23 AM »
I have found Bud Nosen wood to be the best on the market.  Unfortunately you cannot order it direct; however, Tom Dixon will order it for you and have it drop shipped to your address.  He matches the latest pricing by Lonestar.  Make up your order using the form on Tom's website and prices from the current Lonestar ad in Model Aviation magazine.  Fax or send it to Tom and he will make the order for you.  Minimum order amount is $75.00.  Make sure to put your contact info on the order.
He has no email and prefers snail mail.  It is his way and it works out just fine.
Here is his website: http://members.tripod.com/~TomDixon/
Once you use the Bud Nosen wood, you will never go back to anything else!!
Louis Rankin
Somerville Tennessee
AMA 10859
Offline Zuriel Armstrong
Re: Outstanding source for contest wood!!!
« Reply #1 on: November 28, 2007, 01:43:19 PM »
Outstanding Lou.  Tom is a super guy and I'll get an order in today.
Zuriel Armstrong
AMA 20932
« Reply #2 on: November 28, 2007, 03:38:45 PM »
Tom Morris uses the Bud Nosen wood also.  He says it is the best wood he has ever used.  The thing I like about Nosen wood is the consistency.  Thickness is the same from sheet to sheet.
Louis Rankin
AMA 10859
