  • July 17, 2025, 07:50:45 PM
Author Topic: prop clearance  (Read 2134 times)
Online Jim Morris
prop clearance
« on: March 09, 2007, 09:46:42 AM »
What is about the minimum prop clearance permisable on a stunt ship. Mostly fly off asphalt, sometimes grass. this is with tail on wheel.
Offline Andrew Borgogna
  • Andy
Re: prop clearance
« Reply #1 on: March 09, 2007, 10:10:36 AM »
Jim
Having just had a prop clearance issue this past weekend I would say at least 1 to 2 inches with the planes center line parallel to the ground.  I clipped both ends of a wood prop on take off and the engine kept running.  This was on asphalt, the vibration really rattled the plane and lead to damage to one of my wheel pants on the next flight.  I didn't realize the screw holding the wheel pants on came loose and the it rotated 90 degrees and caught the ground on landing.  Minor problem, but it ended my flying for the day.
Andy
Andrew B. Borgogna
Offline Bill Gruby
Re: prop clearance
« Reply #2 on: March 09, 2007, 10:23:58 AM »
Prop clearance would probable be whatever you are comfortable with. I have to agree with Andy, my comfort range is 1 1/2" in asphault, on grass it is a little less, grass being a little more forgiving. Again bottom line here is how you feel.
"Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
Re: prop clearance
« Reply #3 on: March 09, 2007, 10:37:59 AM »
HI Jim
The normal Minimum ..if there is such a thing...is  1 inch on concrete  1.5 inches on grass, That is with the plane level, not sitting back on the tail wheel
Online Crist Rigotti
Re: prop clearance
« Reply #4 on: March 09, 2007, 10:57:05 AM »
HI Jim
That's what I shoot for.  Listen to Randy.
Online Jim Morris
Re: prop clearance
« Reply #5 on: March 09, 2007, 11:19:49 AM »
Thanks guys, I guess Im going to have to remake the gear legs for my Avanti. I only have a little less than 1 in. with tail on wheel. 12" prop. Like to be able to go with a little more prop if needed.
Re: prop clearance
« Reply #6 on: March 09, 2007, 11:32:49 AM »
I've had as little as an half inch. But sooner or later (probably sooner) you will buzz the prop on take off. This is a real problem on low slung classic planes. Go with Randy. At least an inch on pavement and an inch and a half on grass if you want consistent takeoffs without damaging props.
Re: prop clearance
« Reply #7 on: March 09, 2007, 04:02:21 PM »
geeezzzzzzzz, Randy Smith!  you'uns never told us'uns that before!!!  Now I will probably grind down some props because of it!  I have been a'thinkin' that 1/2" was ok!  Really.............  bad thing is that up ' til now, I haven't had a prop problem, now you done gone and jinxed me..............  but then, I haven't even measured it a lot of the time...........when you only get a couple dozen flights a year, there doesn't seem to be too many problems....... :o  :##  LL~
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: prop clearance
« Reply #8 on: March 09, 2007, 04:38:14 PM »
You could just go to bigger diameter wheels; or a 3-blade prop with a little less diameter.
--Ray
AMA902472
Offline don Burke
Re: prop clearance
« Reply #9 on: March 09, 2007, 04:58:33 PM »
I think a good rule of thumb is to have the prop tip no lower than the main gear axle with the airplane at zero degrees (level flight attitude).  More of course would give a safety margin.
don Burke AMA 843
Menifee, CA
