  • July 19, 2025, 01:48:42 AM
Author Topic: Prop Balancers  (Read 1217 times)
Offline Allan Perret
  • Proverbs
Prop Balancers
« on: July 07, 2007, 05:37:28 PM »
What balancer do you guys like/use?
I was reading on the Master Airscrew website about their balancer that addresses both spanwise and chordwise balance.  Any body ever use that system or have any opinions on it?
 H^^
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Peter Nevai
    • C3EL
Re: Prop Balancers
« Reply #1 on: July 07, 2007, 07:48:07 PM »
I never did get that serious with this stuff, more along the lines of some cheap dubro balancer that camw with a bunch of little plastic dowles and straight pins. Worked good enough most times.
I suppose if you were balancing props for screeming high rpm engines then one of the new balancers is the way to go. I dunno. Some of the balancers out there start at $40 or more. A bit steep for my blood, especially when balancing a $4.00 wood prop.
Offline Ted Winterman
Re: Prop Balancers
« Reply #2 on: July 07, 2007, 09:09:58 PM »
       Allen
       The best prop balancer I have ever used is the TOP FLITE precision magnetic
unit. I think they cost about $25.00
       Ted    H^^
Offline L0U CRANE
Re: Prop Balancers
« Reply #3 on: July 09, 2007, 04:54:19 PM »
Alan,
I PM'd you about mine, but a look in the Tower catalog shows the DuBro Tru Spin balancer is very similar.
Take your time, work carefully, clean crumbs before re-weighing. Done right a balanced prop will please you with lowered vibration, which allows the engine to deliver more power, etc., etc.
\BEST\LOU
