According to Leonard Neuman's chart, with the .135" OS spraybar, the venturi should be .265" (stock?) to (around) .281" for a stock .40FP. Uh, that would be 17/64" and 9/32", respectively.
Are you going to use the stock muffler? Which one is it? Look for the casting number...if it's the late type, leave the cone in it. Some say the APC 10.5 x 4.5 is the magic prop, but from all indications, the 11 x 4.5 Thunder Tiger will work as well or better...and cheaper...and nearly perfectly balanced out of the packet.
Howzat Vector 40 coming along? Pictures!!!
