  • July 22, 2025, 02:38:14 PM
Author Topic: Profile Continental..  (Read 2857 times)
« on: August 21, 2009, 10:58:27 AM »
Just wondering if anyone has built one?   I'm planning to build one over the winter, and like to get some ideas.. especially on doing the built-up profile fuselage, tricks to keep it light but strong etc.  also some finishing tips would be great too. as this will be my first big project thats not an arf.. just want it done right.
Thanks in advance.
« Last Edit: August 21, 2009, 04:09:27 PM by Joe Yau »
Offline Bootlegger
Re: Profile Continental..
« Reply #1 on: August 21, 2009, 12:04:22 PM »
Joe, What I have been doing on profile models is use 3/8" balsa, for the fuse, installing the motor mounts to match the engine of choice, cutting out behind the flaps to the l/e of the stab, then put in diagonal (30 degree angle) braces of 3/32" balsa, they are 3/8"wide, cover each side from nose to tail with 1/64" plywood using  2 hr epoxy, in a very thin coat, to adhere the plywood to the sides.
  I usually do one side at the time and I put the fuse on a flat surface between two pieces of 36" or what ever needed plate glass and let cure over night, then do the other side the same way.
  I can't take the credit for this method as Tom Farmer enlightened me to this several years ago, you will add about one once of weight, but the strength far outweighs the weight gain.
  If the two hour epoxy sets up too quick then by all means use a slower curing type...
  Hope that this helps,
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: August 21, 2009, 03:26:27 PM »
Thanks for the detailed infos.  H^^
Offline Leester
« Reply #3 on: August 21, 2009, 05:40:29 PM »
Joe: Check out the PAMPA web site, Larry Cunningham has done several articles on building profiles. Asking Larry would also benefit you greatly he frequents this forum. He details the proceedures that Bootlegger describes.
Leester
ama 830538
Offline James Mills
« Reply #4 on: August 21, 2009, 06:09:42 PM »
Which way is the grain running in the 1/64 plywood?
James
AMA 491167
Offline Bootlegger
« Reply #5 on: August 21, 2009, 07:03:49 PM »
The sheets of 1/64" plywood that I have been using are cut so that the grain run's nose to tail, or paraell to the 3/8" fuse..
Gil Causey
AMA# 6964
« Reply #6 on: August 22, 2009, 09:53:19 PM »
Not sure if I need to be a member or have to log in to see it.. I couldn't find the article in the Pampa website.
Offline Leester
« Reply #7 on: August 23, 2009, 06:10:59 AM »
Joe; At the top of the site click on Documents, then in the pop up click on general. Scroll down and you will see them, I am a member but I think those are available to everyone.
Leester
ama 830538
« Reply #8 on: August 23, 2009, 09:35:02 AM »
Thanks Leester.  H^^
I guess I was clicking on the wrong box.
Offline Ward Van Duzer
« Reply #9 on: August 23, 2009, 12:50:13 PM »
Which Continental?
Dmeco or Worden?
Just curious...I love that little Dmeco.   IDEA!    #^
« Reply #10 on: August 23, 2009, 09:02:16 PM »
Which Continental?
Dmeco or Worden?
Hi Ward,
It will be Tom Warden's Continental..  in Blue, black & white sort of like the pic below, but without the stripes.
« Last Edit: August 23, 2009, 11:52:40 PM by Joe Yau »
« Reply #11 on: August 24, 2009, 03:22:19 PM »
Without the stripes it is not a Continental.  Just kidding, so keep us posted. LL~ LL~DOC Holliday
Offline builditright
  • So happy to be alive!
« Reply #12 on: August 25, 2009, 12:07:24 PM »
if you're interested we make the kit for Tom Wardens profile Trophy Trainer.
If you want the kit or plans send an email to: trophytrainer@builtrightflyright.com
Thank you and God Bless
Walter
aka/ builditright
« Reply #13 on: August 26, 2009, 09:51:47 AM »
Hi Joe,
On the subject of the profile Continental, the first thing I thought of is the Trophy Trainer!  Gotta build one of those, myself. ;D
Larry C. has written a lot about the profile fuselage, and Gil's methods he posted are great.  Yuo have to just pick one of the methods and go with it.  anything to lighten the rear plus adding strength is the goal as far as I am concerned when doing a profile.  Of course, the best flying profile I ever had didn't have anything special done to the fuselage.  Then again, I am the original *Blind Hog*. ;D
Mongo
« Reply #14 on: August 27, 2009, 10:52:59 AM »
Hi Walter,
Could I get some specs (also straight LE or tapered?), and some details on the airfoil used on this plane?  I have never seen it before.
« Reply #15 on: August 27, 2009, 11:10:48 AM »
Hi Joe,
Mongo
I don't know much about the Trophy Trainer though, but I will have a look at it.
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #16 on: August 27, 2009, 11:35:46 AM »
Warning on my Building a Better Profile series still on the PAMPA website.. Quite a bit of that material
is obsolete.
That said, I personally think the Continental is one of the most beautiful classic designs ever. And
without intending to step on any toes, I think it is worthy of full fuselage construction, and perhaps
even a poor candidate for a profile. Particularly if a classic soft light 1/2" sheet fuselage is used;
notice the beautiful slender long aft fuselage?
My epiphany: building a very good profile is almost as much work as building a very good built
up fuselage. Yes, there's cowl and canopy to deal with, and fuel tank placement. But, particularly
for such a magnificent design as Tom Warden's Continental, a full proper fuselage is warranted.
Just sayin', JMNSHO.
And, I have to say, the fine photo of the Continental above with the blue stripes truly shows the
beauty of this design. It's a lovely critter.
L.
"If the facts do not conform to the theory, they must be disposed of." -Maier's Law
« Reply #17 on: September 01, 2009, 09:12:58 PM »
Hi Walter,
it has a constant cord wing from both top and front views
only taper is at the flaps.
Walter
aka/ builditright
« Reply #18 on: September 02, 2009, 04:44:54 PM »
is obsolete.
L.
Hi Larry.
I have to agree that the Continental is one of the most beautiful classic designs..  I really likes the  lines on this plane.  The reason  I wanted to build the Profile version was mainly so I could have a nice stunter to compete in profile class.   and the blue coloured Continental in the pic was photoshop in to the same blue I’ll be using.
BTW:  Is there an updated articles on the Profile Fuselage?
« Reply #19 on: September 02, 2009, 04:49:46 PM »
Thanks Walter.  It looks pretty good.
« Last Edit: September 03, 2009, 09:36:47 AM by Joe Yau »
