  • July 22, 2025, 10:20:36 PM
Author Topic: profile c/l horns  (Read 1343 times)
Offline Bootlegger
profile c/l horns
« on: August 28, 2011, 10:36:37 AM »
 :!   Guy's where are y'all gettin your profile control horns?
 In particular I am looking at 1"-1 1/4" tall horns.   Thanks,Gil y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Paul Taylor
Re: profile c/l horns
« Reply #1 on: August 28, 2011, 11:23:34 AM »
Gil
I get the heavy duty ones. Also sometimes I get the left and right horns and put them back to back.
Offline Ward Van Duzer
« Reply #2 on: August 28, 2011, 11:27:02 AM »
Buy straight (unbent) 3/32" ( or 1/8") wire horns and bend them off center as needed.
w.
Offline Bootlegger
« Reply #3 on: August 28, 2011, 11:42:59 AM »
  Thanks Paul and Ward, Paul where do you get yours at?
  Again thanks...
Gil Causey
AMA# 6964
Online Paul Taylor
« Reply #4 on: August 28, 2011, 01:25:38 PM »
Gil
Tower has a good selection. I have used the heavy duty T type or like I said put two back to back for more strength.
Offline Bill Allen
« Reply #5 on: August 28, 2011, 01:34:30 PM »
Gil: The BEST profile horns are available from Tom Morris...w/wout adjustable slider.  The pilot can make incremental changes n travel as is needed. You'll spend extra time for installation but the results are worth it. IF you want me to walk you thru it verbally and/or with pix I'll be happy to do it. Currently (as I type) constructing my 2nd Fancerized TWISTER using these with laminated flaps/stab/elevators. This process gives you an absolutely STRAIGHT hinge line!  My e-mail is  allen.wm42@Yahoo.com or (815)-758-0741.  Regards/ Bill Allen
« Reply #6 on: August 28, 2011, 02:55:44 PM »
Take a look at these, if you're looking for bolt-on horns for FS's, Ringmasters, etc.:  y1 Steve
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFV36&P=7
« Reply #7 on: August 29, 2011, 02:40:30 PM »
HI Steve,
I have looked at those metal ones many, many times.  How do they work in the air?  It seems they would be much stronger than nylon ones.
Thanks!
Offline Paul Wood
« Reply #8 on: August 29, 2011, 04:02:48 PM »
HI Steve,
Thanks!
Bill,
I have used those horns many times on R/C aircraft.  They are very good, but....  The plastic inserts that the control rod clevis passes through are very suseptible to UV deteriation.  I recently dug a couple out of my junk box to use on a scratch Nobler.  The plastic plates crumbled in my fingers.  The remaining holes in the metal are pretty large.  You might be able to sleeve them, but I didn't have the courage.
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #9 on: August 29, 2011, 04:57:01 PM »
I'd say to use whatever you would use on a full fuselage model. Get the unbent ones and custom bend them for the needed profile offset. There's virtually no difference in the flap and elevator control horn functions on either type of model. It takes similar hardware and effort to get similar control smoothness and feel.
I wouldn't use the wimpy little RC bolt on type referenced above. Just me, they may be wonderful, but I prefer wires on the control horns. If I were inclined to use a bolt on tab type horn, I wouldn't use a metal one, unless it had a proper brass tubing bushing soldered to it for the control rod - nylon is a good bearing material and will not egg out like an unbushed thin metal unit.
Good luck!
L.
"An autobiography is the story of how a man thinks he lived." -Herbert Samuel
« Reply #10 on: August 29, 2011, 05:06:34 PM »
Mike Haverly has used the Sullivan 1 1/8" metal horn on several models, and likes them for Barnstormers, Ringmasters, etc. I'm pretty sure he slices off the plastic bit and uses 4-40 ball links, maybe with a bushing. You do need to reinforce the elevator or flap area to take the fastener compression. I'll agree with Larry C. on the flaps, but the Sullivan horns will work fine on the elevator of a profile.  y1 Steve
« Reply #11 on: August 29, 2011, 06:21:25 PM »
I've gotten good at making them out of 1/8" lite ply H^^
Offline Jim Morris
« Reply #12 on: August 29, 2011, 07:06:29 PM »
I made mine out of aluminum for my kit bashed Twister.They look like the nylon ones in the kit. I found that the nylon ones will flex with ball links.
