  • June 27, 2025, 01:28:05 PM
Author Topic: Top flite Nobler  (Read 2391 times)
Offline Andrew Saunders
  • 2013 Nats
Top flite Nobler
« on: March 11, 2014, 06:36:11 PM »
Last year at the beginner NATS i received this Top Flite Nobler. This will be my second one so i decided to change it up a bit. I dont like the fiberglass cowling that comes with it so I  am making my own. Also made my own tank cover. Just taking a chance to learn and experiment. If it doesnt work, then ill cut it off and use the original Fiberglass cowling.
Offline 55chevr
Re: Top flite Nobler
« Reply #1 on: March 11, 2014, 06:41:52 PM »
Photo?
Joe Daly
  • 2013 Nats
« Reply #2 on: March 11, 2014, 07:27:14 PM »
Here are pics of what i have so far.
Offline 55chevr
« Reply #3 on: March 11, 2014, 07:54:54 PM »
Love Noblers .... what engine are you using?
Joe Daly
  • 2013 Nats
« Reply #4 on: March 11, 2014, 08:10:12 PM »
The largest engine that can be used in this one is an OS MAX LA 46. Im gonna use a Magnum XL 40.
« Reply #5 on: March 12, 2014, 10:59:59 PM »
I'd bet $.05 that the Magnum XL .40 is considerably heavier than the OS .46LA. You might want to check that and consider your options.  H^^ Steve
  • 2013 Nats
« Reply #6 on: March 13, 2014, 04:39:17 AM »
I'm using the magnum XL .40 because its an engine I already have and I Don t have to spend any money.
« Reply #7 on: March 13, 2014, 10:25:11 AM »
Way to go Andrew.  Go with what you have.  I have a EVO 36 on the nose of my ARF Nobler.  No cowl as I wanted the engine out in the open.  Had to add lead to tail of the Nobler to get it back to where it would turn.   Haven't notice any difference in the flying other than it now has more power.   Was powered by a Fox .35 Stunt.
« Reply #8 on: March 13, 2014, 04:01:17 PM »
I really, really, really (did I say really?) need to put my ARF Nobler together.  When I got it (years ago, now) I did all the control updates, etc., and that is where it stopped.  It will be worth it now that I am returning to flying.
BIG Bear
RNMM/AMM
  • 2013 Nats
« Reply #9 on: March 13, 2014, 07:10:02 PM »
Bill you will love the ARF Nobler. They fly great especially with the control upgrade? Did you go to a 4 inch bellcrank? What engine are you gonna use in yours?
Offline Balsa Butcher
  • High Desert Flier
« Reply #10 on: March 13, 2014, 07:31:15 PM »
I did a Tom Dixon style cowless front end for a friends TF ARF Nobler. Don't have pics but you can just extend the sides to a Nobler profile. Add a front piece made of 1/2" balsa with a hole in it for the prop shaft. Carve, sand and shape to taste. Balsa block over the top, open on bottom. Engine slips in from the bottom, removable tank show horns in the same way. Stronger than a removable cowl. Something you may want to consider. 8)
Pete Cunha
Sacramento CA.
AMA 57499
  • 2013 Nats
« Reply #11 on: March 13, 2014, 07:45:45 PM »
Do you have any pictures of what you did? Any Pictures of the Tom Dixon Style cowless front?
« Reply #12 on: March 14, 2014, 03:30:14 AM »
Hi Andrew,
I am hoping it flies as well as my Green Box Nobler did years ago.  I did go with a 4" BC.
I set it up for a Double Star .40.  I run a larger than stock venturi and head shims since the engine was set up FAI style.
Without the hours of finishing in the ARF, I will not be as worried flying it especially since it has now been over two years since I flew a pattern.
BIG Bear
RNMM/AMM
  • High Desert Flier
« Reply #13 on: March 14, 2014, 10:12:26 AM »
The plane has since been crashed but I'll see if the person who has it can dig out the pieces and I'll take a few pics. Not too difficult a mod. The original Oriental (not the ARF) is set up that way also.  8)
Pete Cunha
Sacramento CA.
AMA 57499
