  • July 18, 2025, 10:57:43 PM
Author Topic: Primer Bulb  (Read 1745 times)
Offline ray copeland
Primer Bulb
« on: January 30, 2017, 05:11:54 PM »
Anyone know where to find another one of these? I found it at a swap meet years ago, it is the best little primer bulb for 1/2a's and I always grab it to skeet a little fuel in a gummed up engine. It is so easy to just get a drop of fuel where you need it.  I believe it was an oiler of some sort at one time, maybe for sewing machines or such. Would love to buy a couple if I could find them, afraid this one is going to leave me some day.
Online Motorman
Re: Primer Bulb
« Reply #1 on: January 30, 2017, 05:21:55 PM »
blank
« Last Edit: March 06, 2022, 09:32:51 AM by Motorman »
Offline Russell Shaffer
Re: Primer Bulb
« Reply #2 on: January 30, 2017, 05:30:35 PM »
A place that sells fishing gear will have something called a "worm blower".  It's intended to squirt air into a nightcrawler but it works fine for engine priming.  It has a short steel needle so you can use it one handed.  Mine has lasted for years.
Russell Shaffer
Klamath Falls, Oregon
Offline Target
  • C/L Addict
Re: Primer Bulb
« Reply #3 on: January 30, 2017, 06:16:57 PM »
I've seen bottles like that for drawing oil samples from a dipstick tube in diesel engines. But the tube was larger.
R,
Chris
Chris
AMA 5956
Offline david beazley
Re: Primer Bulb
« Reply #4 on: January 30, 2017, 06:33:01 PM »
Woodcraft supply has something like that, 6 pack for 10 bucks
https://www.woodcraft.com/products/workshop-glue-injector-bottles-6-pack
They call them glue bottles, i use them for oil so probably works with fuel.
AMA # 2817
Offline David Hoover
Re: Primer Bulb
« Reply #5 on: January 30, 2017, 07:08:01 PM »
Best, Hoovie
Re: Primer Bulb
« Reply #6 on: January 30, 2017, 07:42:36 PM »
Thanks guys for the heads up on the woodworking glue bottles, I will order some tomorrow! Russell, I have fished with night crawlers for a lot of years and have to say the "worm blower" is a new one on me, I looked it up and now I have to get one. Thanks, Ray
Offline Chancey Chorney
Re: Primer Bulb
« Reply #7 on: January 30, 2017, 07:47:41 PM »
Found it locally. I knew it was something rc car related. I found a RC car bearing oiler. Only difference is that it is not the accordion style, just smooth plastic.
Offline Keith Miller
Re: Primer Bulb
« Reply #8 on: January 31, 2017, 05:27:31 AM »
That's an ink-jet refill bottle.
