Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 21, 2025, 01:51:13 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Pressure fittings
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Pressure fittings (Read 1207 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
Pressure fittings
on:
September 02, 2007, 06:32:58 PM »
Hello Fellow's
I am looking for some suggestions on the best size pressure fittings on a muffler.
I don't know if the 4-40 or the 6-32 fitting will be best.
I'll be using them on 40 powered ships, and using muffler pressure is new to me.
Thanks for the advice,
Oh where do you get your fittings anyway ??
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Re: Pressure fittings
Reply #1 on:
September 02, 2007, 06:47:26 PM »
Why? You can cure the upwind/rich downwind/lean thing in other ways. I've seen too many cases where a leak in a muffler pressure system caused way more grief than that. Blown exhaust gasket, loose muffler tailcone, leaky muffler pressure line, loose muffler pressure tap...so far. Not many around here use it, and they're finding out that they don't need it. More power doesn't happen!
Technically, all your pressure line needs to do is refill the tank with (polluted) air, replacing the fuel volume as the engine burns it. While I'm not sure a 4-40 pressure tap would be enough (they're made for crankcase pressure), there's no reason a 6-32 wouldn't be plenty.
http://flyinglines.org/McClave.LA40.html
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Wynn Robins
Trade Count:
0
Admiral
Reply #2 on:
September 02, 2007, 09:43:40 PM »
I only run muffler pressure and have never experienced any of the above issues - all engine runs are the same - all good to the last drop of fuel.
cant help on the sizing tho - I just run OS LA46s and they come with the pressure nipple there.
Logged
Jim Thomerson
Trade Count:
0
Admiral
Reply #3 on:
September 05, 2007, 03:01:42 PM »
I run muffler pressure when I can. I figure if I am going to lug the weight of a muffler around, it can do some work for me. When I don't run muffler pressure I use one-way valves on the uniflow and that works fine also.
Logged
taildragger-j3
Trade Count:
0
Lieutenant
Me over 1/2 century ago with my Ringmaster Jr.
Reply #4 on:
September 05, 2007, 03:13:56 PM »
I've had to replace a few pressure fittings, and I use 4-40. It seems to be plenty of pressure, and I have a 4-40 drill & tap. I've gotten a few taps at a LHS in Houston. I'm pretty sure that Tower Hobbies has them, too.
Logged
David Strawn
Aggieland, TX
AMA - 10212 (original!)
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Pressure fittings
