  • July 18, 2025, 04:31:07 AM
Author Topic: pressure fittings  (Read 926 times)
Offline Bootlegger
pressure fittings
« on: April 25, 2010, 12:01:21 PM »
  Some time back I remember seeing a question about pressure fittings, the question was which is better for stunt, 4-40 or 6-32.
 I don't remember the suggestions as to which is better, so I'm asking again.
   Thanks, Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: pressure fittings
« Reply #1 on: April 25, 2010, 02:41:01 PM »
You talking about pressure fittings or mounting bolts.  In reality a lot depends on the engine being used.   H^^
Offline Bootlegger
« Reply #2 on: April 25, 2010, 03:10:12 PM »
 Pressure fittings to create muffler pressure to have a steady pressure to the uniflow on the tank.
  Didn't mean to create confusion. Thanks for pointing that out Doc...
Gil Causey
AMA# 6964
« Reply #3 on: April 25, 2010, 03:13:45 PM »
Well I have several Fox mufflers that have 4-40 threads.  On the OS mufflers I think they are 6-32.  Which do you need or are you just adding one to a muffler? H^^
PS: Opening in the Fox is 1/32" jeh
« Reply #4 on: April 25, 2010, 04:29:22 PM »
Also M3 or M3.5.
In the past, 4/40 was pretty much standard, so you could insert the pressure fitting in lieu of one of the backplate bolts.
A crankcase pressure fitting needs a tiny hole to restrict the pressure.
A muffler pressure fitting needs a gapping hole to get all the pressure it can,  Thus, a muffler pressure fitting would be better off with a 6/32 or M3.5 thread.  Or for that matter, a chunk of 1/8" tubing glued in with high temp epoxy.
Offline Bootlegger
« Reply #5 on: April 25, 2010, 06:41:28 PM »
Doc, I sent ya' a p m..  Thanks, Gil
Gil Causey
AMA# 6964
