Congrats on making the save. Here is a suggestion on how to fix it. I'm assuming you have already cut a hole in the fuse to trouble shoot the problem. Cut away all the plastic from the horn. Make a new horn arm from brass or steel, and after you drill the hole for the horn wire, cut a slot to one side so it will slide over the wire. Take two flat washers and do the same thing. Try to make things so that they are a friction fit and will stay where you put them. Wire wheel everything nice and shiny.Install the arm with one washer on each side, and stagger the slots. Use Stay Brite sikver solder and flux, and solder everything in place with a 40 watt iron, making sure everything flows well around all three pieces. If it all looks good, that should last the life of the model. Hook you flaps back up and re-trim the controls and replace the piece you cut off the bottom and you're done.
Good luck with it,
Florissant, MO
