  • July 08, 2025, 06:15:55 AM
Author Topic: Precision Aerobatic capable biplane.  (Read 22740 times)
Re: Precision Aerobatic capable biplane.
« Reply #50 on: December 26, 2016, 08:29:40 AM »
Been plenty of kits & plans for em , One a 72 in R C , as a base ?? Hoff
This Waco was a Pica kit, I think 1/7 scale at possibly 55", I'd have to measure it.
Was my R/C flagship.  LL~
The model is so old, the iron on covering is falling apart. I'll look for another OS 90 which is what I had in it, then I can do a recover and add some detail.
Nice for scale and T&G's but the airfoil isn't symmetrical.
Charles
Offline Blaine Buchtel
« Reply #51 on: December 26, 2016, 09:49:18 AM »
I'm more interested in traditional or. "semi-scale" biplane. Thanks for the question!
« Reply #52 on: December 27, 2016, 04:53:54 PM »
Apparently theres a Dave Platt & a PICO Kit for the YMF3/5 at 60 in. span , and a PICO at 72 span . Presumably the one I saw in NZ with White red stripe picture on box . Not that its a control line stunt kit . But perhaps something to start butchering  %^@ to taste , or scrible over the R C Scale drg.
« Reply #53 on: December 27, 2016, 05:16:54 PM »
No , but thank you for wondering! Looking for a traditional, or " semi- scale" bipe. Regards,  Blaine
« Reply #54 on: December 27, 2016, 05:51:44 PM »
Bart Kaplinski did pretty well with his Fleet biplane flying in Old Time at VSC.
Oh the other hand, Bart could fly his garage door through a better pattern than most of us mere mortals!  Probably power it with twin Fox .59s so that it could be heard coast to coast.
Ted
« Reply #55 on: December 27, 2016, 05:56:00 PM »
This is the best bipe stunter I have ever watched. Mr,T's TIGHT, powered by Saito 82(?). He got 10th place at '11 Japan Nats. Not only flew very well but also was very beautiful and won the most beautiful model of the year prize. No plan, sorry.
Aki
WOW!!
« Reply #56 on: December 28, 2016, 04:22:09 PM »
More Assine drivle .  :o
The Renowned Snyder Mc Ready .  ???
Plan for a rubber band job is in same A. M. as Al Rabes p 51 series Mag . 78 ??
Theres a simlar Square rigged WW1 ? 1916 ? Mexican fighter , hispano suiza SQUARE RIGGED snaffall stagger straight linejob .Penut scale Plan in one American Mag .
Both of these'd make simple light semi scale , near scale , or just Purloin the look type LIGHT WEIGHT ships , if you made the light weight . stick & tissue ,
id be inclined to Wire Brace em with say .015 wire to take the flying & landing ( inverted ) Loads , Spruce 1/2 x 1/8 vertical for the wing spars , or suchlike .
Maybe this is something to do with it , Two seater Version ? .
For Real Men a SBC-3 Helldiver , Brent Williams wing & moments ??
Been Kaz's F6 & some F4s , Grumman Iron works rolled Tube Fuselage , moulded . good to have the retracts . ;D LL~
Im sure someones done a profile of this , cool looking aeroplane .
Offline Steve Thompson
« Reply #57 on: December 28, 2016, 05:48:24 PM »
"More or less make bottom wing at 0 degrees and top wing just a hair negative" - from Dan's post above
I have read this also, but don't know where.  Is this primarily for full scale planes and RC models where upright flight handling, stalling, and landing manners are most important?  Would this apply or be relevant to a CL airplane?
Does the hair negative incidence for the top wing translate to just don't have it positive?
I am building a 38Spl and have the wings done and the fuse almost done.  I have been planning on aligning everything at zero - zero.  Now I am wondering...
« Reply #58 on: December 28, 2016, 06:08:00 PM »
   Hi Steve;
    My .38 Special kit is at the bottom of a BIG stack of kits and hard to reach. What does the plan and instruction say about jigging up the wings when attaching to the fuselage. May have to do a search and see what John Miller has to say on the subject, or see what others may share. I'm really curious what the Brodak book and plans say, given that the examples I have seen fly here seem to fly really well, even in the hands of beginner and intermediate class type pilots. What ever the plans say or the book says must be good.
Offline Serge_Krauss
« Reply #59 on: December 28, 2016, 07:28:36 PM »
Blaine -
Here are two excellent SH threads on biplane stunters:
http://stunthanger.com/smf/stunt-design/almost-finished-with-it-my-stunt-biplane/
http://stunthanger.com/smf/open-forum/why-no-competitive-biplanes-in-stunt/
I have six posts in the first and five posts in the second. For clarity and brevity, I recommend the second URL, but most aspects are discussed in each, with many other contributions by some of the better sources on the internet. My main points are that biplanes have theoretical maximum efficiencies of 200% those of "equivalent" monoplane wings, but more practical ones between 100% and 137%, except for box wings that can go as high as 147%. What brings them down about even to monoplanes is aspect ratios and applicable Reynolds Numbers.
I recommend these posts, plus some in the SSW Forum archives. Searches here work well too.
SK
« Reply #60 on: December 29, 2016, 11:24:00 AM »
The negative incidence concept has been mentioned in earlier posts in this thread above.
Hal deBolt wrote about it in his article on the deBolt Bipe in the July 83 issue of Model Builder.  The airplane dates back to the 40's with flat bottom airfoil.  Remember, this article discusses his thinking in the design evolution of that airplane over 40 years prior to his MB article.  In his article, he wrote:
"The proper use of decalage can enhance longitudinal stability.  The law ways that if you fly the forward wing at a higher angle of attack than the aft wing, then the forward wing will stall first, thus the forward wing will lose lift while the aft wing maintains it.  In that case the center of lift automatically moves rearward tending to pivot the nose downward at approximately the center of gravity, or control pivot in this case once the nose comes down, the forward wing gets it lift back and you are flying safely once more.  ... The Bipe uses two degrees of negative incidence in the rear wing for this purpose."
Now, fast forward to the Dutchess/Dancing Girl/Tiger Rag/Cavalier series of biplanes by Peter Miller.  (Dutchess - Aeromodeller, Aug 74; Dancing Girl - Model Airplane News, Feb, 75; Tiger Rag - Model Aviation, Mar 82; Cavalier - Flying Models, Nov, 99)  These four designs represent a even longer series of airplanes by Miller.  In his two part 1974 article on the Dutchess, Miller does not mention any wing decalage.  Then, with his 1975 article on the Dancing Girl, Miller mentions stability problems with all of his previous biplane attempts.  He then references the old deBolt Bipe article with "1o negative incidence on the top wing, so I tried it and the stability problem vanished..."  In this article, Miller then explains the evolution from 10% to 18% airfoils with the Cavalier and "Instant success, Cavalier flew the full schedule."  In his 1982 article on the Tiger Rag, Miller writes "The layout... seems to be the optimum for this type of model:  thick wing section, equal area for both wings (with the thrust line passing just above the center line of the gap between the wings), large stabilizer and elevator with big control deflections -- and no flaps.  Light weight is also a critical factor. ... Care must be taken with the lower wing seat to ensure that it sits a 0 degrees incidence."  The plans for his Tiger Rag show the top wing to be mounted with "-1o incidence".  Then, in his 1999 Flying Models article on the Cavalier, he summarizes the series by saying his Cavalier proved he had hit the right formula with the 18% section and 1o negative incidence on the top wing.  His article mentions the "vital 1o negative incidence" in the top wing.
TROSTLE NOTES:
1.  I am not sure of the accuracy of the information deBolt provided in his 1983 Model Builder article regarding the negative incidence on the bottom wing.  Somehow, deBolt's findings from the 40's was later translated by Miller and others that it is the top wing that is to have negative incidence.  (These later developments were prior to the Model Builder deBolt article.)  I would certainly go on the series of articles and plans by Miller and use the 1o negative incidence on the TOP wing.
2.  There are several "successful" biplane designs that have been mentioned in this thread, like the Hutchinson Stearman (based on the J.C. Yates design which is very close to scale), Sheeks' Staggerwing (semi-scale), Jim Hunt's TravelAir (scale), Hinton's "59er", Claus Maikis' Duetto, Don Yearout's Biceps, the several Italian and Japanese designs (if plans are available) and on and on.  I would recommend as a starting point to use the Miller Cavalier. It is the result of a long evolution of CL biplane stunters.  If not just build to his plans, then at least use his layout for proportions, airfoil, and the negative incidence on the top wing.  You will also need lightness and power.
« Reply #61 on: December 29, 2016, 11:55:42 AM »
Dan , Serge, Keith,
Thank you for your input and sharing your knowledge on the top wing negative incidence part of this thread.
The plans that came with the Brodak 38 Special kit are hand drawn but extending the chord lines of both wings shows they are clearly drawn to be parallel (zero - zero).
I will shoot for zero - zero, make sure I don't get positive in the top wing, and if it comes out 1 degree negative on top, I will sleep soundly.
If the top wing turns out to be 1/2 degree negative, I will say I used extensive jigging to attain that.  Heeee.
« Reply #62 on: December 29, 2016, 12:14:17 PM »
Dan , Serge, Keith,
    Barring any specific information applicable to CL Stunt, I would certainly start there. I can see some reason, not very good, to move them both (one positive and one negative, I won't venture a guess as which one goes which way) but in general I would expect them to want to be 0-0.
  • Gravitywell
« Reply #63 on: December 29, 2016, 01:56:27 PM »
It should be fairly simple to design the top wing so you can set it at zero and then adjust it to -1 degree.  Would make for an interesting comparison. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #64 on: December 29, 2016, 02:21:25 PM »
I had the same thought myself. Would make for an interesting experiment! Thanks.
« Reply #65 on: December 29, 2016, 04:29:44 PM »
The basic idea that Glenn proposes here is good.  However, most of the literature I have seen suggests it best to have the bottom wing at -1o.  (See the comments by Peter Miller above with his years of experimenting with biplanes.)  If the top wing is made adjustable, then why not make it adjustable through a range of say -2o to +2o?  That would mean the angular difference range of the bottom wing would be from +2o to -2o respectively.  Would save having to reinvent the idea of what works best instead of building a whole series of biplanes which has already been done.  From the literature, the difference in wing incidence from one wing to the other appears to help make the airplane more stable.  (In Miller's case above, he found 1o negative incidence in the top wing to be advantageous.)  So then, the question comes up about what to do with the thrust line.  I would think that thrust line sensitivity would be small if not negligible if the angular differences of the two wings are in the range of say +/- 1o or even +/- 2o and would have little sensitivity.  So for this exercise, just live with the thrust line being constant.  If, on the other hand you build a biplane with an upright (or inverted) engine, you would also be able to change the thrust line as well.
Structurally, an adjustable incidence top wing should not be too difficult.  Just need to be careful that the change in incidence is locked in and constant at each of the wing attach points.
Good luck.
« Reply #66 on: December 30, 2016, 11:16:05 AM »
All I know is my 38 Special flies mucho better than I do.  It is built box stock wit OS 40 for power.  Need to dust it off again like so many of my other planes. H^^
Offline Tom Niebuhr
« Reply #67 on: December 30, 2016, 06:01:07 PM »
Do I sense interest in a Biplane event??????
Doc Holiday reports that he likes my Vagabond.
As originally designed the span is 34" to do Slob type flying but with a better glide and an aluminum landing gear to correct tendencies for the gear bend back and hit the lower wing.
Increase the span by one rib bay at each tip and the span becomes 39.25 " and would be good for a .4o or .46 engine.
Increase the span two rib bays and the span will almost 46" good for a .56 or .60 engine.
The larger version might also benefit from a longer tail moment. Increase the motor mount width to suit the engine.
http://stunthanger.com/smf/open-forum/vagabond/?action=dlattach;attach=237694;image
AMA 7544
« Reply #68 on: December 31, 2016, 03:19:24 AM »
 LL~ LL~ LL~ LL~ LL~ LL~ LL~
Offline Tom Niebuhr
« Reply #69 on: December 31, 2016, 03:24:03 PM »
Matt.
Look in the BiSlob title block you will see that I drew the plans (And wrote the article.
The Vagabond is a NEW design using the Hobo ribs. ( I also designed the Hobo)
AMA 7544
« Reply #70 on: December 31, 2016, 11:12:28 PM »
And they both do what they are supposed to do.  Thanks to Tom. H^^
Offline Chuck_Smith
« Reply #71 on: January 01, 2017, 06:36:23 AM »
He he, check out what the wing incidence is for a Pitts or a Christen Eagle. Not an early Pitts, but say an S1S.
AMA 76478
Offline Allan Perret
  • Proverbs
« Reply #72 on: January 01, 2017, 10:13:28 AM »
Hey Tom: Liking the looks of this Vagabond.  I would build it as a sport stunter with normal control throws and thrust offset.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Tom Niebuhr
« Reply #73 on: January 01, 2017, 02:21:46 PM »
Allan,
I wish I had the time to build several versions of the Vagabond. But, my efforts now are to build a new design Pampa ship that I call "Ragtime" It will be my first electric and is very different from everything that is out there at this time.
The .40-.46 size Vagabond with the added rib bay will fly great, with normal engine off set. I can get plans to you for cost of repro and shipping.
AMA 7544
« Reply #74 on: January 01, 2017, 03:03:22 PM »
They look good planes . The Bi Slob must be ideal for a novice getting through the pattern ,, with its ' all the time in the world ' for corrections , and tight turns for avoidance of Terra Firma .
How does the Vagabond go for that , with the straighter thrust line ? looks like a straightforward build , youd be in the air before NEXT Christmass ! .  8)
Perhaps this ones not ideal ,  :-\
« Last Edit: January 01, 2017, 03:52:03 PM by Matt Spencer »
« Reply #75 on: January 01, 2017, 08:25:34 PM »
The Vagabond is very easy to build.  Tom picked the slowest builder to build one.
« Reply #76 on: January 01, 2017, 08:35:24 PM »
     The BiSlob is the worst possible stunt trainer, it teaches you entirely uncompetitive approaches and does absolutely nothing "honestly".
« Reply #77 on: January 01, 2017, 10:08:49 PM »
ANYBODY"D THINK IT WORKED FOR THE GOVERNMENT !
 LL~ LL~
Was thinking more  ' The Ab Initio ' trainer . For someone whos getting along ok with level flight . The way they trundle round , anybody with two brain cells should be able to get along fine TRYING manouvres .
just to get the reflex/ sequence in order . Rather than any ' geometric niceties . They can come later . My Views someone who can position the plane anywhere at will , can cope with ' the pattern '
But not neccesarilly Visa Versa .
A Competant * plane in resonable air , having the ' CONTROL ' sequeces in the right order , ( Memory Recall - 1/2 Doz min for Memory . )Like a Motorcycle Track , and your on you way , as long as you dont get distracted .
( * Aeroplane with NO Line Tension ' irregularities ' . )
I should think a Bi Slob Pilot being abused by a proficent instructor could manadge ALL the FAI Schedule Manovres , If ( definately ) NOT in the Correct Size Height etc , at least in a semblance of the correct shape .
Thus Learned , he could then proceed to open up to the correct proportins & geometry , at a later stage. Another Chapter in His/ Her Progress , No Doubt .
BUT The THING would get thru the shape sequences , at altitude , with time to spare for thought & observation .
Just My Humble Opinion .
A Pommy Profile Peacemaker'd do it to , on 60s . But They BREAK if you bounce them, And it'd be inevitable  .
A Bi Slob it'd be inevitable That Youd Crack Up / Fall Over Laughing . Rather than the Aeroplane doing so . Its Ability to ' Hang on a Line ( Wire ) being one necesity , For How to Ham Fist a Stunt Patern .
« Reply #78 on: January 03, 2017, 07:31:37 AM »
My search online revealed that a Pitts S1S has a upper wing incidence of 1 and 1/2 degrees with the lower wing at 0"/0" degrees. Not sure if this has any meaning for our models? Regards to all,  Blaine
Offline Skip Chernoff
« Reply #79 on: January 05, 2017, 06:17:55 AM »
Will the 38 Special make a nice square corner?
Offline Carl Cisneros
« Reply #80 on: January 05, 2017, 07:48:43 AM »
Maybe something along these lines?
Carl R Cisneros, Dist IV
Control Line RB
« Reply #81 on: January 05, 2017, 10:14:43 AM »
Mine makes a good square corner.  The last times I flew it made my patterns look good. H^^
