Several years ago, I built some Ringmasters and shipped them out and people seemed to like the idea of them being semi built. What I did was build the wing with the bellcrank installed with the leadouts attached, built the fuselage and tail feathers and shipped them out in a guitar box. The recipient had to glue in the wing and tail feathers, cover and paint the wing, fuselage and tail feathers and install the glow engine of their choice and go fly.
Today we have some addtional choices. First of all, I can build the Ringmaster as a take apart, covered and painted and five 4-40 bolts and blind nuts will attached the wing, stab and vertical fin and rudder. In addition, you have the choice of using glow or electric propulsion systems. You just have to specify what kind of power you will be using and the front end will be prepped accordingly. I can also cover the wing and paint the fuselage and tail so that all you have to do it intall the electrics or glow engine and tank and go fly.
Here is what I am going to offer as a service and I will try to be as detailed as possible about this.
I will buy the laser cut take apart kits from Eric Rule at RSM. I will then build the wing, fuselage and tail sections. The blind nuts will be installed in the correct places so that when you open the box, all you have to do is screw the plane together. In addition I am going to cover the wings with plastic film and will paint the fuselage and tail pieces. Basically, you will open the box, screw on the wing and tail pieces, put on your electrics or glow engines and tanks and go fly. When Eric developed the take apart Ringmaster, it made this a lot easier for me to do.
I will pick a couple of colors of paint and covering and that will be the scheme.
I am going to try and keep pricing under $120.00 If I can. (do not chisel this in stone yet but it should not vary much from this) I dont think that is too bad for a ready to put together airplane painted and covered.....
I will have to do some figuring on shipping but when I say $120.00, that is just for the plane ready to be put together and fly.
Anyway, let me know if you think this service might be of value to you or someone you know. I can only offer this within the United States.....
