I remember a guy that had a black head when they first came out. He had it on a "NoBody",Don Still flying wing. The NoBody had a very thick wing and needed power to fly it. It was the fastest combat model around for a while.
This is my take on Don Still’s NObody ... first edition (1959) with an OS Max .35 combat engine, 4 oz. metal tank, weighed 18 ounces. At nearly 500 square inches and, as Ed says, a thick airfoil, it was surprisingly fast!
Trophy in the (very old & poor) photo is from the 1959 MN State Championships. In the first round, my opponent’s launcher stepped on his streamer, so the match was stopped. When my engine quit, the judges hollered out they would give me 10 minutes for my engine to cool off and then we’d restart.
So I decided to have some fun and wind flew for the 10 minutes. When you got that thing going and then pulled a sharp turn so the wind hit that 500 squares at a 90 degree angle, it was almost like it was shot out of a cannon!
My opponent didn’t even start his engine for the rematch.
Second version (maybe 5-6 years later) also came in at 18 ounces, but was built like a tank. I used 1/8” vertical spars at the high point of the airfoil (which I located at about 40% of the chord) and also near the trailing edge, along with a carved leading edge. The leading edge, ribs and spars were all hollowed out at points, and of course the engine was mounted on its side.
It was another terrific airplane, even better for wind flying because of the engine mounting, and the structure was much, much stronger and warp resistant.
Don’s original used ribs placed at angles behind the high point, which probably made it much stronger and more warp resistant than my first attempt.
Thanks for stirring that memory, Ed!
Dennis
PS: I have full size plans + the construction article for Still’s NObody. If anyone wants to build one, let me know.
