  • July 22, 2025, 09:57:41 PM
Author Topic: Prather Reverse Pitch Prop Gauge  (Read 2017 times)
Online Crist Rigotti
« on: May 27, 2009, 06:51:46 PM »
I took a regular pitch gauge and turned into a reverse pitch gauge for our electric pusher props. I simply turned around the face, attached a new pitch scale, which I drew up using my CAD program, attached the arm, then notched the arm to clear the screw. I've included a .pdf of the new pitch scale full size.
Alan Hahn
Re: Prather Reverse Pitch Prop Gauge
« Reply #1 on: May 27, 2009, 09:41:22 PM »
I thought you could put the pitch gauge next to a mirror and measure a pusher prop that way. ;)
Online Howard Rush
« Reply #2 on: May 27, 2009, 10:22:16 PM »
Alan, I am worried about your sense of humor.  Coincidentally, I posted much the same observation on SSW just now.
Alan Hahn
« Reply #3 on: May 28, 2009, 03:48:41 PM »
Well I like to think I am a clever fellow y1, but in actual fact, I had just changed my tractor APC12-6E for the pusher APC12-6E on the ENobler and to my surprise  n~ my lap time went up--- quite a bit actually. So when I got home, I pulled out my Prather Pitch gauge, mounted the pusher prop and then began to scratch my head. Then I realized that the universe isn't chiral symmetric, and neither was my Prather. Now if I could only change the pusher into antimatter, then to a pretty good approximation I'd be ok with the pitch gauge.
But since I am only a sport flyer ;), I decided to take a nap. Z@@ZZZ
Online Howard Rush
« Reply #4 on: May 28, 2009, 03:54:34 PM »
I had an antimatter prop once, but I didn't have anything to carry it in.
« Reply #5 on: May 28, 2009, 07:43:37 PM »
Wow, a honest to goodness hijacked thread!
« Last Edit: May 29, 2009, 06:39:15 AM by Crist Rigotti »
Alan Hahn
« Reply #6 on: May 29, 2009, 01:10:12 PM »
Well you are still ahead 2 postings out of 3 on this subject!
