  • July 25, 2025, 08:15:45 PM
Author Topic: Prather pitch gauge  (Read 1246 times)
Offline kevin king
Prather pitch gauge
« on: August 29, 2019, 01:21:57 AM »
Does anyone have a Prather pitch gauge handy? I lost the aluminum block that holds the prop and I need to know the height the  prop is off the gauge. Then I can make a new prop holder for it. Thanks.
Re: Prather pitch gauge
« Reply #1 on: August 29, 2019, 05:51:29 AM »
  Jim Lee sells a replacement prop holder for the Prather pitch gauge that is wider and more steady, just FYI.
Offline TigreST
  • TigreST
« Reply #2 on: August 29, 2019, 06:10:32 AM »
Prather prop block dimensions:
Overall length: 1.5”
Block Overall Height(includes Tee tongue):  .624”
Overall Width:  .752”
Width of Tee tongue: .181”
Tee tongue depth:.225”
Prop Stop pin height above block: 1.30”
Prop post height: .80 (above block top surface).
« Last Edit: August 29, 2019, 08:09:30 AM by TigreST »
Tony Bagley
Ontario, Canada
Offline kevin king
« Reply #3 on: August 29, 2019, 02:49:27 PM »
Thanks everyone 👍
« Reply #4 on: August 29, 2019, 08:59:11 PM »
I found the Jim Lee block to be much more stable than the stock one!
« Reply #5 on: August 29, 2019, 09:19:39 PM »
Kev, once you get another prop slider block thingy, you'll find the lost one, of course. There is a way to help prevent losing one, that has worked pretty well for me. I put the whole gauge and peripherals in a cardboard box AND leave a broken propeller bolted to the slider thingy. Works so far!  #^ Steve
Offline BillLee
« Reply #6 on: August 30, 2019, 04:31:02 PM »
Not to mention that it doesn't make any difference.
Bill Lee
AMA 20018
