You dont BUILD practise planes , they just get to be that way .
just keep nailing it back together .
At least , if your flying ' any weather ' and ' learning ' how to get through the gales .
My second phantom ended up a every other day ship . FSR 25 & 55 ft. eye to eye .018 steel seven strand . Usually .
It'd had ST 21 / 35 , 21/40 & OS 35 then ST 35 C before the nose fell off .
https://stunthanger.com/smf/nostalgia-30/phantom-f4ef-ish/msg428603/#msg428603 . the camo. shark mouth one )
A new nose & trick set up FSR clone , ( a totaL fluke ) . Worst wind was 30 Kt .Full Pattern on a 25 , Reqd a bit of leaping about & leading .
Hit the deck 2 Doz times . Winter the bog was soft .
Lines Tight & it'd go in square . A lot less disasterous than in a yaw .Through Trees , into a concrette cricket pitch inverted .
Hosed out . Threee days in the car in the sun to dry it out , after that .
a ten minute wipe with a rag and petrol took 3/4 hour to get the worst of the castor & lawn clippings off .
Anything straight with good controls is worth giving a hard time .
Pieces on 2 x 4 and rippings , blocks etc etc for the inevitable repairs .
Set it on the bench with straight edges , or clamp them on T E , Spars , or LE as the case may be - So it SETS STRAIGHT .
Using PVA avg. 2 days clammped . longer when its a monsoon , shorter in high summer .
My thoughts the Oriental / Nobler size , 48" T E & Tips , will fit in the car boot / trunk .
Any old engines a start , FP 35 / 40 FP 25 , FSR 25 etc etc . Mount holes oversize , 5/32 drill ( 4 mm )
gets a degree off interchangeability . Bolts in sans motor , stretch to pattern , so the nuts aligned to the angled bolts.
BEFORE fitting ' another ' engine . The SIDE MOUNTED engine is less prone to tearing the head off ,
Tho OS 703 etc mufflers will break . A good trick on later mufflers is cut 1/2 thru bolts , maybe at stack face ,
so something more expensive dosnt get trashed , in ' the odd glancing blow .
Thatll learn you SMOOTH on the Controls , And Leap to get the lines tighht , & never say die .
