It is not legal because it does not have a side mounted engine. I would not be opposed to do as Ted suggests and rotae the engine mount to a side winder position to meet the criteria. A LOT of people seem to forget that the original intent of the profile class, and most clubs refereed to it as "Profile .40" or shortened to "P-.40 Stunt". It was intended as an easy does it entry level class. One advantage of a profile model for beginning and intermediate level flyers is that you can leave all the control points exposed for easy adjustment and change. The same with the engine and tank installation. Having a side winder engine presents a challenge to get a proper engine run, but because of the exposed nature of the components, adjustment is easy. Engine size was limited to no larger than a .40 because of the many engines available and for lesser cost. Everyone has a .15..29,.35 or a .40 of some kind laying around. I believe SIG was the first to hold the event many years ago and they started the 10 point bonus "no flaps rule." We here in the St. Louis area adopted that set of rules for our contest because many of us attended the SIG contest through the years. We have always pointed that out in our contest flyers, and P-.40 Stunt was always one of the largest entered events at the SIG contest. This was all at least in the mid-1990's. Mike Pratt designed the Primary Force specifically to fit these rules. I think Ted Fancher came up with his "Doctor" for some of the same reasons, lots of .40's out there and eliminate the flaps to make trimming easier. In both cases, the designers hit the proverbial nail on the head, and Mike Pratt is working on an update to the Primary Force. Over the years, many clubs just started to massage the rules for their own events, allowing larger engines and "Rabe" front ends. All Rabe started the upright engine profile trend with his "Mustunt" series. And why did he do that? It makes it EASIER TO SET UP THE ENGINE FOR THE BEST RUN! This however eliminates the challenge of setting up a side winder engine. Not the first time that has happened to a new event, and certainly won't be the last.
Now, to further drive home the profile variety, our club has decided to levee a ten point penalty to electric models entered in profile at our contests. This was done to keep in the ORIGINAL INTENT of the rules, which were developed long before electric models were practical, and the main reason being there is a distinct advantage to running an electric power plant because there is no "side winder" position for the motor or tank position to determine. We gave this a lot of thought and discussion and decided to hold to the original intent of the event. I'll volunteer that it was my idea, as I'm sort of a traditionalist! If you are angered by this, we are sorry but all of our contests will be run this way this year, at least. If you want to counter act the penalty, build an electric profile model with no flaps and pick up the 10 point bonus!
Hope this helps some understand.
