My experience with ABC engines were mainly K&B 6.5 in Fast Rat.
The first one received pulled the plug, back plate, All was spotless. turn it over by hand. Whoa, no way!
Mounted prop, turn over, WHAT THE HELL IS THAT BIND AND HORRIBLE SQUEAK!?!?!
Called John Broadbeck(?) after lapping didn't help. Think it nearly gave him a heart attack when I told him I tried
lapping it and then he gave me ABC lessons an the jigging,boreing, fitting, short version 'that's the way it supposed to be.'
When cold-bind Hot- no bind.
When the bind(cold) went away so did power and hot start.
Me? I would heat with gun or propane and see if it goes away....if so all is problem ok.
Do not never ever run rich like iron engine or there will not be enough expansion to have it a Hot Fit
and wear will be rapid. Fuel, prop that you plan to run and run it. 1st run possibly just backed off peak+ if it makes you feel better.
That's real ABC, No telling what your being sold now other than from others post seem quality control in fit
is a problem.
