  • July 17, 2025, 01:59:16 AM
Author Topic: Polyspan on an i-beam  (Read 1612 times)
Offline Bill Sawyer
« on: September 26, 2008, 12:07:27 AM »
Has anyone done this? I just wondered how it worked out. I recently bought some but have not tried it yet.
Bill Sawyer
AMA 53987
Windancer Models
Offline Ralph Wenzel (d)
Re: Polyspan on an i-beam
« Reply #1 on: September 26, 2008, 06:07:56 AM »
A couple of years ago Sparky said that he'd never again use anything other than PolySpan on I-Beams.
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #2 on: September 26, 2008, 07:20:21 AM »
I've used polyspan on an I-beam with great results. I love the ability to use
a heat gun to do final shrinking after the polyspan has been doped into place.
Offline tom hampshire
« Reply #3 on: September 26, 2008, 07:47:57 AM »
I have used poly on several conventional wings (sheeted from L/E to spar, with capstrips and sheet T/E) and found it OK.  BUT it lacks strength compared to either silkspan or silk.  Puncture resistance is better than silkspan, about the same as silk, but it adds very little torsional strength/stiffness.  So it works well on a conventional wing where the structure, not the covering, provides the torsional stiffness.  I have not found it good at all when used on a non-planked wing, with top and bottom spars and open bays.  Steve, has your polyspan I beamer been flown in heavy turbulence?  I'd be hesitant to try it without some real world experience with flexing under heavy loads.  Certainly a stiffer structure penetrates turbulent air much better than a 'flexible flyer'.   Have you experienced this as well?  Tom H.
Offline John Miller
« Reply #4 on: September 26, 2008, 03:15:34 PM »
It might be the time to point out that Gordan Delaney's 2 or 3 time Nat's winning classic, Collosuss, designed by Jim Tichey, an I-beam of about 700 sq inches, is finished with polyspan and dope.
« Reply #5 on: September 29, 2008, 07:44:19 PM »
I have polyspan on my Sheeks Spitfire and see no problems other than the plane needs someone that knows how to fly it.  DOC Holliday
