Are you asking about an on board system or external for starting? sounds like external
I use two methods...
On my non combat flight box a 12VDC 9AH gel cell powering a Hobbico Accu-Glo mkII that is CURRENT adjustable but constant 1.5VDC and a close-pin type glo plug clip
My other for combat birds is a Hand held RCATS glo driver with lithium battery that is computer (logic) controlled like Howard Rush's design
http://rcatsystems.com/rc.php 5200 mAh battery capacity for long battery life (over 1 year with normal use)
Adjusts current automatically to keep the plug lit
Soft Start slowly delivers current to prolong plug life
User-selectable startup delay feature (~5 seconds)
Built in charging system
Auto shut-off
Easy to read LED bar graph
Modular plug clip for easy customization
Internationally rated power supply (100-240V, 50/60Hz)
