General control line discussion => Open Forum => Topic started by: Terry Caron on November 30, 2015, 09:27:42 PM
Title: Polyspan by any other name.........
Post by: Terry Caron on November 30, 2015, 09:27:42 PM
I read in another thread on polyspan that it's the same stuff used as "interfacing" on clothing.
Anyone know if it's the same as Pellon interfacing?
Terry
Title: Re: Polyspan by any other name.........
Post by: Perry Rose on December 01, 2015, 04:45:28 AM
I believe pellon is thicker. I looked at that several years ago I may be mistaken, no that's impossible.javascript:void(0)
Post by: john e. holliday on December 01, 2015, 08:45:03 AM
I have not seen any thing in the fabric stores that comes close to Poly-Span.
Post by: Gordon Van Tighem on December 01, 2015, 01:18:43 PM
Check the bottom of your bed's box spring. Similar material?
G
Post by: Terry Caron on December 01, 2015, 01:43:30 PM
I haven't gotten any yet, just researching.
Fabric stores sell several weights, sew-on, iron-on.
Terry
Post by: Keith Renecle on December 01, 2015, 10:15:37 PM
Hi Terry,
I've been through the same kind of research and even managed to email the first guy to use this for free-flight....Klaus Salzer (hope the spelling is right). It is Polyester non-woven fleecing tissue that weighs 18 grams per square metre. It's used for many things, one being interfacing as you mentioned. It was also used for something in fiberglass moulds and insulation in big fat electrical cables. I managed to source one called Dacmat here in Darkest Africa that came from somewhere in the USA. It was a bit thicker but took less dope to fill it. It was also 500 mm wide and I used it for years. I believe that Tom Morris has a certain type as well that is a better price than Polyspan.
They all have the same problem because the fibres are sort of hot pressed together and the thinners in the dope tends to cause fuzzies that are a real pain in the butt. There are however many threads on this amazing forum that help to do a good job with poly tissue. My source of Dacmat dried up unfortunately. What I found works better for me right now is to use medium weight tissue over thin laminating film. It comes out lighter mainly because it is a lot easier to finish. Good tissue here in South Africa is not something you can buy easily from any hobby shop, but I got hold of some teabag tissue and it is identical to medium weight tissue. It also weighs 18 grams/sq.metre. The laminating film is iron-on-heat-shrink stuff and is dead easy to use. Most print supply shops keep the stuff. I believe that this is an old free-flight trick and many use light weight tissue with very thin Mylar under it to stop the tissue from puncturing. A good friend and member of SAM in Canada also told that for the cabin type models, you also get free "glazing" this way! #^ The laminating film however is easier to use because it has the heat sensitive glue on it already.
Keith R
Post by: tom brightbill on December 01, 2015, 10:45:28 PM
I decided to try some locally available dress lining, what appeared to be almost as light as that which Tom Morris sells. It did not have a smooth, shiny side.  It also did not take dope the same as Tom's. Heat shrinkage was similar. But without the smooth initial surface (like Tom's) it required much more final finishing. Not worth it in my opinion. As long as Tom carries his version, that's what I'm going to use.
Post by: Terry Caron on December 01, 2015, 10:59:08 PM
A local fabric shop has it for <$1.00/yd.
I'm going to check it out in a day or two, a shiny side is one of the things I'll look for.
Keith - lack of success w/iron-ons is why I'm looking at this stuff - I cut my teeth on silkspan but I have little of it left.
Terry
Post by: Steve Helmick on December 01, 2015, 11:14:54 PM
Mike Haverly used the lightest "dress liner" from the fabric stores for several years, but finally gave up on it for weight reasons. Cheap isn't always a good deal.  H^^ Steve
Post by: john e. holliday on December 02, 2015, 10:29:10 AM
Poly-Span from Stunt Hanger Hobby or Tom Morris is the only way to go.   Patience, and the right tools do the job.
Post by: dave siegler on December 02, 2015, 10:42:13 AM
I would not expect that Polyspan is made for modellers.  I would expecet it is some kind of fabric that is re-purposed.
I showed polyspan to my boss who is a fabric artist ( quilts, fabric dyeing) and she said Oh I know what that is.
She got me a sample of Pellon p45JAS.  it looks like the real thing to me.
see this for product selection there may be lighter options
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiuwsqQ3L3JAhUCUT4KHQxTBR0QFggkMAE&url=http%3A%2F%2Fforum.missouriquiltco.com%2Fattachments%2Fquilting-questions%2F37896d1359317011-pellon-product-guide-pellon-product-guide-printable-version.pdf&usg=AFQjCNH6WlNW9Zmjp8QcKWBYTHzIVIDQ8A&sig2=O_dIU4nyQVUHDsUAJcIM5w&bvm=bv.108538919,d.cWw (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiuwsqQ3L3JAhUCUT4KHQxTBR0QFggkMAE&url=http%3A%2F%2Fforum.missouriquiltco.com%2Fattachments%2Fquilting-questions%2F37896d1359317011-pellon-product-guide-pellon-product-guide-printable-version.pdf&usg=AFQjCNH6WlNW9Zmjp8QcKWBYTHzIVIDQ8A&sig2=O_dIU4nyQVUHDsUAJcIM5w&bvm=bv.108538919,d.cWw)
Post by: Fredvon4 on December 02, 2015, 01:53:36 PM
Thanks for that Dave
My wife is a machine quilter and sewing hobbyist and I do most of the on line ordering for her supplies. We actually share quite a lot between the hobbies. She looked at my Poly T from Tom and came back to my shop with a scrap that I swear is the same stuff (have not tested, just look and feel)
When I told her how much my roll from Tom was she asked me to get her some cuz his price was better than she pays JoAnn fabric for the stuff
Post by: Terry Caron on December 02, 2015, 02:28:00 PM
Fred, do you know the stock number of the material your wife uses?
Terry
Post by: Fredvon4 on December 02, 2015, 03:52:04 PM
Terry sorry brother her dad is in the hospital recovering from by pass surgery and she is out east helping her mom with him. May be a few weeks before she returns and I can get that info (I doubt she knows it off the top of her head but I will ask tonight when we talk
It is material she buys locally on sale from JoAnns or Hancok fabricks.... we rarely keep the receipts so I have no trail to follow right now
Post by: Terry Caron on December 02, 2015, 03:57:15 PM
Thanks Fred, no prob.
Best wishes and prayers for your family.
Terry
Post by: dennis lipsett on December 02, 2015, 06:27:44 PM
Go to google and type in p-45jas sew in interfacing material. This took me to the closest store in Reading carrying the product. It is $0.99 a yard. I have someone who is familiar with Polyspan and she has a sample. I'll see how my source pans out. Meanwhile you can check and see where you can get it at using the above procedure.
Dennis
Post by: Brent Williams on December 03, 2015, 12:42:31 AM
I stopped by JoAnn's this evening ad took a picture of the Pellon P45 JAS interfacing.
I don't have any Poly-Span to compare it against, but I could do so later this week.
Post by: john e. holliday on December 03, 2015, 09:11:35 AM
Will have to recheck my local Jo-Anns.  That is where I get the colors of poly-eater cloth.  It is a heavier material more like the heavy weight silk span.
Post by: Motorman on December 03, 2015, 12:58:28 PM
The thrill of sourcing something for models other than at a hobby shop.
Kieth, if I was covering a model in deepest Africa I'd just put lion skins on it.
MM
Post by: Terry Caron on December 03, 2015, 01:06:55 PM
For me, the benefit of stretching very scarce hobby dollars.
Also, some don't live near a LHS.
Not living in Africa, I tried deer skin - too heavy.  LL~
Terry
Post by: Tim Wescott on December 03, 2015, 02:23:25 PM
http://www.dharmatrading.com/fabric/silk/silk-habotai-fabrics.html?lnav=fabric_silk.html (http://www.dharmatrading.com/fabric/silk/silk-habotai-fabrics.html?lnav=fabric_silk.html)
Two yards of 55" wide material should cover a whole lot of planes for $10.
Post by: Terry Caron on December 03, 2015, 02:55:22 PM
I've never used silk before, didn't know it was so (relatively) inexpensive.
To weight in a sense no doubt, but to what does the metric designation refer specifically?
Terry
Post by: Tim Wescott on December 03, 2015, 03:05:06 PM
It's not a metric number (not millimeters or meters).  It's some weird measure of the weight of silk: https://en.wikipedia.org/wiki/Units_of_textile_measurement#Momme (https://en.wikipedia.org/wiki/Units_of_textile_measurement#Momme).  8mm is about 1 ounce/square yard (according to Wikipedia).
I haven't personally used their silk (I should have said -- sorry), but those who have recommend the 8m.
Post by: Terry Caron on December 03, 2015, 03:23:01 PM
Thanks for the clarification, Tim.
So 8mm silk would be heavier than the lightweight Pellon.
BTW, the relative inexpense I referred to above is "relative to my previous notion".   ;D
Terry
Post by: Tim Wescott on December 03, 2015, 03:56:24 PM
Well, yes.
The free-flight guys use laminating film (web search on laminating film and on DoculamTM).  Look for PET films (no, I don't know what "PET" means in this context).  Some use tissue over laminating film.  I haven't tried it.
Post by: Motorman on December 03, 2015, 08:57:16 PM
What thickness of laminating film is good for open wing bays on our planes?
MM
Post by: andy borgogna on December 03, 2015, 09:23:31 PM
Polyester Film (PET)
PET or polyethylene terephthalate film is a thermoplastic polymer commonly referred to as polyester film. Like most thermoplastics, PET films can be biaxially oriented or bubble extruded. Polyester film is one of the most common substrates used in the converting industry because of its balance of properties in relation to other thermoplastic polymers. PET Film is comparable or better then other thermoplastics in the following categories:
Post by: Dan McEntee on December 04, 2015, 06:24:02 PM
    HEY!! CAN HE SAY THAT ON THE FORUM????? What ever it was he said! Hey Andy, speak English! What is it and where can I buy it easily?
    Learning the ins and outs of this interfacing material ought to include the different weights of the different "sizes." I can see using something a bit heavier for a model that you might expect will take a bit of abuse and punishment. I'm thinking of trying it under Monokote. I think John Miller has a method of covering with Monokote over a layer of silkspan, and using the polyspan type stuff instead might be pretty bullet proof for a balloon bust airplane. A larger scale model might call for a heavier weight material. I'll be watching for other people's results, and maybe get some of my own!
Post by: john e. holliday on December 04, 2015, 06:38:55 PM
I just bought some of the material at Jo-Anns Fabric Store.     They all kinds there on the shelf.  Some of it had a weave to it.   Found the Pellon P45 JAS and got 2 yards of it.   It does look like Poly-Span and silk span.   It also tears very easily with the grain but not across it.   Will be putting it to the test on a stab/elevator  in a day or two.    99 cents a running yard.   About 20 inches wide.
Post by: Terry Caron on December 04, 2015, 06:42:07 PM
Doc, does it have a shiny side like polyspan?
Can you give us a weight/sq yd?
Terry
Post by: john e. holliday on December 04, 2015, 06:54:09 PM
Both sides looked the same in the store.  In the shop one side does have a slight sheen to it.  The package the material came off of said 100% poly ester.  So it should shrink with care.
Post by: Mark Knoepfle on December 04, 2015, 07:39:32 PM
Good job Doc! I'm waiting on your report.
BTW there is another material called stabilizer for embroidery that is also very similar...
Post by: dennis lipsett on December 04, 2015, 09:20:09 PM
Dan,
I've posted this before but putting film over silkspan is relatively easy. The edge 540 wings/stab and elevator were covered with silkspan and then all of the other colors were applied with individual cut pieces. Not too difficult to do and as a side benefit film sticks tenaciously to silkspan so there is no wrinkles. The fuselage was painted to match
Post by: Fredvon4 on December 05, 2015, 08:13:57 AM
My wife confirmed last night that the JoAnn's Pellon P45 JAS interfacing is what she showed me and to my 60 year old eyes looks and feels identical to RSM
After thinking about it I think she and I were incorrect about RSM's was cheaper  15" x 20 feet @$18 I think is $2.79+/- a yard
I had told her the roll was 20 yards...my bad
Post by: Shawn Lenci on December 05, 2015, 08:32:27 AM
You guys got me all excited reading this thread.  I went to JoAnn's last night and bought a 1 lineal yard of P45 which is about 18"-20" wide.  At the register was a 40% off coupon for any 1 non sale item.  Price out the door was $.43.  I guess I could do some experimenting for $.43. :)
Shawn
Post by: Terry Caron on December 05, 2015, 09:51:34 AM
Can you weigh your piece accurately Shawn?
A quick calculation would give the weight/sq yd.
Terry
Post by: Motorman on December 05, 2015, 10:05:19 AM
Does the RSM polyspan tear easy one way and not the other? Don't you want the fabric to be strong in both directions?
MM
Post by: Fredvon4 on December 05, 2015, 10:18:13 AM
I took the piece of JoAnns stuff my wife gave me and cut a 12x36 inch piece...weighed 11.3 grams on my powder scale...so mine is 33.9 grams a sq yard or 1.16 Oz /Sq Yrd
Post by: Terry Caron on December 05, 2015, 11:10:32 AM
Weighing a piece of heavyweight silkspan, it's an RCH (an old machinist's term meaning "insignificant") over 1 oz/sq yd.
Terry
Post by: john e. holliday on December 05, 2015, 11:57:33 AM
Silk span,  Poly-span and this new P45 will tear easily with the grain but not across it.  I've already tried it.
Post by: Terry Caron on December 05, 2015, 12:33:10 PM
So if our calculations are correct (SGM silkspan @ 1 oz, 8mm silk @ 1 oz and Pellon @ 1.16 oz per square yard), material weight difference is perhaps less significant than the weight of paint necessary for a filled finish on each.
Terry
Post by: john e. holliday on December 05, 2015, 08:22:04 PM
I would say that is where most weight comes from is the finish, especially the under coats that are not sanded enough.
Post by: Mark Knoepfle on December 05, 2015, 09:10:09 PM
Doc - perhaps you can answer this... why is polyester better than silk (if it is)? Is silk that much stronger? Can silk be heat shrunk or is it all in the dope to make it tight? I am asking because it looks like we have a choice of both cheap habatoi silk and polyester interfacing.
Mark
Post by: john e. holliday on December 06, 2015, 03:16:44 PM
It has been so long since I used silk, but I do remember it had to be put on wet and pulled tight.  Almost all my combat wings had some kind if dihedral because the bottom was covered first and the top side of the wings.  Never used an iron or heat gun.  It was always air dried.    At the time nylon was what we used for absolute strength.  But nylon was only as tight as you could get it.  Yes, some times the butyrate would cause a little shrinkage.  By the way silk is stronger than poly-span in my opinion, but harder to apply for me.   Also it has gotten very expensive.
How many remember the Sil-Ray covering.  If put on the wrong direction it would sag between the ribs.
Post by: Terry Caron on December 06, 2015, 03:32:52 PM
From SAM (so maybe more for rubber FF?), this link is on covering with polyspan:
http://www.antiquemodeler.org/sam_new/covering/assets_2/polyspan_covering_myers_nystrom_jan_2006.pdf
Same source, on covering with silk:
http://www.antiquemodeler.org/sam_new/covering/assets/covering_with_silk01.pdf
Terry
Post by: john e. holliday on December 09, 2015, 12:50:35 PM
Well I don't have a picture yet,  but I have the top wing of the Vagabond covered with the Pellon P45 JAS.   It reminds me of the heavy weight silk span that I have.  The big difference is it has no sizing which is what I think gives Poly-Span it sheen on one side.  Also thicker than Poly-Span.  Had to thin the dope and put on more coats on the TE & LE.   For the wing tips I used Elmers White Glue and my sealing iron.  The sealing iron also helped stretch it around the tip.  For some reason the dope was taking longer to set up.   Maybe the multiple coats I put on.   By the way don't drag the iron across the grain.   Once I get it shrunk and some dope on the open area will try to get a picture.
Post by: Target on December 09, 2015, 10:13:27 PM
Dan,
Dennis-
Not sure I follow you on this.
The individual cut pieces are film, like monocote?
I read in the 1/2a forum where the poly span is put on, then thin SLC over it to give it a shine and toughness.
Is that how you did the plane in the picture? Was this SLC that was pre painted then applied over the fabric on the airframe?
I'm a bit confused here.
Chris
Post by: Mike Lauerman on December 10, 2015, 06:31:24 PM
Doc:  Excellent report on the application/selection, as usual...
But, in which direction did you lay the grain? Concern is twofold:
First, you mentioned that it 'tears' with grain, but not across;
Second, which direction on wings, so as not to sag between ribs?
Following this thread with much interest, as I had tried something that resembled silkspan in the '70s.
Went on nicely...but after the 3rd coat of Nitrate, the stuff literally shredded!
I know it's not the same stuff, but lessons are learned hard.
Thanks!
Post by: john e. holliday on December 10, 2015, 07:07:19 PM
Okay, like silk span and poly-span the grain needs to go span wise, not chord wise.   Shrunk the covering today and applied a coat of dope.   As usual the first few coats take time to set.   Had one spot the gun got to.    By the way I use only butyrate after a bad mix up.
Post by: dennis lipsett on December 10, 2015, 08:21:49 PM
Dennis-
Chris
[/quote
Chris,
It is MonoKote applied over silkspan. The pieces are cut from patterns and applied individually to the surface. You won't have problems with air bubbles getting trapped and as I stated you cover the wing with silkspan but you do not dope the open framework. Your applied Monokote wont ever pucker. Overlap is minimal and overlaps are not overly obvious. This is actually a lot easier than using a lot of tape to mask off your design. Since I painted the fuselage I can attest that it was a lot of work to get it done compared to the flying surfaces.
Post by: Target on December 10, 2015, 08:37:31 PM
Thanks Dennis for the confirmation.
Plane looks great.
R,
Chris
Post by: Motorman on December 10, 2015, 08:47:24 PM
I just bought some P45, do you think it tears a little too easy in both directions?
MM
Post by: Mark Knoepfle on December 10, 2015, 08:55:19 PM
Doc - thank you for trying this out! How many coats to fill the span? How much heat gun did you need to bring the span up to tight? And after a couple of questions with a couple other guys how did the tips come out? Did you have to heat and stretch to pull it around or did it lay out nice?
Mark
Post by: Terry Caron on December 10, 2015, 09:58:54 PM
Doc, since weight was one of the negatives attributed to poly/P45, did you by chance weigh anything for before/after cover and finish weights?
Terry
Post by: john e. holliday on December 16, 2015, 11:30:46 AM
Well I now have several coats of dope on the material.  All I can say now is it would work in a pinch if Poly-Span was not available.   Has a very rough texture to it and the dope is not filling it like I think it should.  Oh I will finish the plane, but I think true Poly-Span is the only way to go for your plane you want to look nice with out all the work.  More later as I keep working on it.   Trying to do a sanding job on it now.
Post by: Terry Caron on December 16, 2015, 11:41:49 AM
Someone noted a lack of the sizing that true polyspan has and others have commented on the fuzziness after doping - I wonder if a coat of thinned white glue after covering and stretching (possibly needing a bit of sanding) but before doping would seal it, making the finish easier?
Terry
Post by: Lauri Malila on December 16, 2015, 03:13:29 PM
I think it's more about technique when you want to avoid fuzziness. Wet brush coats without rubbing, sharp sandpaper when sanding.
But still if only doped, some areas will become fuzzy in use; leading edge and dihedral joints in FF for example. For that reason I cover (carbon) D-box with paper instead of Saltzer. L
