General control line discussion => Open Forum => Topic started by: Paul Taylor on June 24, 2008, 06:28:09 PM
Just doing the poll for the fun of it.
But I do want to know if a LA .40 will have what it takes to haul the plane. Right now with the LA .40 it weighs in at 49.3oz on my new scale.
Paul H^^
LA 46, easier to get a good run, more steady and its lighter!
I agree with Mark as I have seen several "Tutor II" fly. DOC Holliday
Have to laugh at that "lighter" comment. What is it? 0.2 oz. or so? The TT II's I've seen haven't been notably light. 49 oz. sounds pretty good. With the right prop, venturi size, and fuel the 40 would be fine. I agree that the LA 46 does seem to be easier to get running well though. Like most series engines built on the same case, the smaller one seems to like to run a bit faster than the larger, and of course, the smaller one will not turn as large a prop.
Ok Phil, yeah its like .25 oz I think, but hey its lighter! lol,, I have run both and personally I would opt for the 46 every day all day just because of the run characteristics. 10 22 fuel, 12.25 x 3.75 apc, launch around 9800 its a goer for sure,,
Hog out the head a little to lower the compression and they run pretty sweet......not my idea, but it works great.
Phil
INteresting, Pat and I have been working towards the same solution , it does seem to stabilize them just a bit.
So how do you Hog out the head???
I am definitely NOT an engine guy, but seems to me head shims would do the job instead of hogging it out.
I, too, would go with the LA46 - mine runs great with no mods except a ST51 NVA and a bore out to compensate for the lrager diameter of the NVA. I'm swinging a 12" x 4,25 three blade Bolly that I nicked last year with my bigger ship and saw it was okay to cut down.
I have it on a Tuter two also. Does very well.
Blessings,
Will
FWIW Yes, head shims will work but they have a major drawback. The change the glo plug depth at the same time. This is not a good thing. By machining the combustion chamber deeper it will lower the compression and not change the plug depth. If you need proof of this, take the long plug out and replace it with a short one.
"Billy G" H^^
Also by shimming up the head you are moving the squish band away from the piston top at TDC, making it less effective, which is bad for an even flame front during combustion, which in turn causes erratic power strokes.
Phil
Isn't the face of the plug supposed to be flush with the combustion chamber? DOC Holliday
I hope that you guys know that the OS40/46 are not designed for a long or short plug but the OS plug which is a medium.
Dennis
Yes Doc, you are correct but using the head shims you have moved the plug farther away from the top of the piston. The fa rther away you go the less effective the bang.
"Billy G" H^^
I WAS having some trouble with my OS 40 running in the Vector then I called up Jim Lee and he sent me a Venturi and NVA .....WALA! Trouble free from that point on. Much simpler than Shiming or hogging out the head.... Give it a try.... you'll like it!
T
I Flew my Tutor II with a Tower 40. Plenty of power, excellent runs with a 11X4 APC and Mac's Pipe and a .010 head shim added. Absolutely no line tension problems. Plus the .018 chains are not required.
