  • July 22, 2025, 05:43:44 AM
Author Topic: Plywood types  (Read 2209 times)
Offline jim gilmore
Plywood types
« on: July 02, 2009, 02:23:06 PM »
I'm ordering wood and need some plyw2ood to boot but whats the differences and uses for ( lite ply ) vs (3 ply birch ) ?
Offline Bill Gruby
Re: Plywood types
« Reply #1 on: July 02, 2009, 02:41:20 PM »
 Lite Ply is made from Poplar and is more flexible than Birch plywood. I really wanted to sa the difference is about $4.00.  But what the hay the first sentance tells you what the difference is. Have fun.
  "Billy G"   VD~
Bill Gruby
AMA 94433
MECA 5393-10
Offline jim gilmore
Re: Plywood types
« Reply #2 on: July 02, 2009, 02:46:11 PM »
So for engine doublers I'd want the birch Not the poplar ?
Offline Ralph Wenzel (d)
Re: Plywood types
« Reply #3 on: July 02, 2009, 03:14:39 PM »
Absolutely!
Ralph Wenzel
AMA 495785 League City, TX
Offline jim gilmore
Re: Plywood types
« Reply #4 on: July 02, 2009, 03:18:16 PM »
Ok second type ? To make belcranks from plywood and balsa or doublers for around the belcrank post ? birch also ?
Offline Jim Oliver
Re: Plywood types
« Reply #5 on: July 02, 2009, 03:45:24 PM »
Jim,
The lite ply is usually only 3 plys, and quite soft---not so good.
The aircraft grade birch ply "used to be" 7 ply, but the 5 ply stuff should be fine.
Cheers,
Jim
Jim Oliver
AMA 18475
Re: Plywood types
« Reply #6 on: July 02, 2009, 03:50:59 PM »
You can still get 7 ply. I've also used some 1/32" 5 play Oak veneer plywood that was interesting. Mostly, just the birch 5 ply stuff in 1/16, 1/32 and 1/64.
