Nobody makes a VERY tiny sandblaster for cleaning glowplugs that I know of, however
I've had some luck with cleaning plugs by
GENTLY scrapping away deposits with
a teenie pin, or even an Exacto knife- while the plug was sitting upright and flooded with
fuel and also attached to a glow plug clip with the setting on low. It will get hot pretty
quick, and the fuel will burn away quick too. But the deposits will loosen up 'some' with
the heat and fuel. It will give off a bit of a stink too
, as the fuel and gunk burn off.
When you get some of the goop loosened up, turn the plug over and dump out and
shake/flick the now dirty fuel out. Repeat as required, turn off the glowdriver before
adding more fuel to it- ie: don't burn yourself!
You have to be careful, as
you can and will short out the element, so the glowdriver has to be set low,
otherwise you will burn out the plug! Sometimes this works, sometimes the plug
is too far gone or too dirty. Give it a try on more plentiful, available plugs first.
Maybe someone else has a better cleaning method??
Stan Bidowski
