  • July 06, 2025, 12:10:03 PM
Author Topic: Profile Stunt Model Description  (Read 1011 times)
Offline Garf
    • Hangar Flying
« on: December 03, 2012, 01:27:41 PM »
There seems to be no clear definition of a profile stunt model anywhere. The AMA has it defined for rat racing and combat models and a few others. The Brits have a basic description of a profile, but I doubt we would be happy with that. The people that run contests that include profile stunt need to get together and work out a description of what is or isn't a profile model. It would head off possible problems later.
Re: Profile Stunt Model Description
« Reply #1 on: December 03, 2012, 03:14:43 PM »
Offline Crist Rigotti
« Reply #2 on: December 03, 2012, 04:16:18 PM »
There's no getting together needed.  It is up to the local contest director to decide how profile will be flown at his/her contest.  Simple.
Offline Douglas Ames
« Reply #3 on: December 03, 2012, 05:36:31 PM »
Use the "Scale" specs. and build accordingly.
AMA 656546
« Reply #4 on: December 04, 2012, 05:51:14 AM »
That's too easy.   It's too hard to contact Contest Directors and see what local rules are for that contest.
Offline Bob Whitely
« Reply #5 on: December 06, 2012, 06:13:17 PM »
Whatever the local CD says it is, it is, period. Also it is casual to the most obvious
observer what is and is not a profile. It's either a built up fuse or it ain't.
Besides what difference does it make? You like profiles, fine. You like
full fuse models, that's great too. I don't like profiles cause it takes too much
work to build everything else just to hack out a slab fuse. I can understand that
some may be unable to build a full fuse plane so I am happy for them. Trouble is
if you can build a wing and install the controls a full fuse is a piece of pie,uh,cake.
Of course there is no challenge to an ARF or ARC as 99% of it is done for you.
Like Doc I would ask the CD what the rules are and go from there. This isn't
difficult.  RJ
« Reply #6 on: December 06, 2012, 08:21:27 PM »
Ya Know...
When my horses are dead I just bury them and cry a little...beating one makes no sense.
« Reply #7 on: December 07, 2012, 08:18:58 AM »
We sent ours to the dog food factory/processor.
