So a 13" prop corners without too much wobble but a 12" prop doesn't really pull overhead like you want. Interesting, I did not know that. I guess the same holds true for electric. I wish I knew that before I made my 12" prop maker lol. Oh well I know a guy that welds aluminum, I can make extensions. Thanks Brett.
Hmmm, I didn't say anything about 12" props, since we aren't using those. But the engine response and pitch makes more difference than the diameter. One of the most successful systems in stunt history pulled a 700 square inch, 64 ounce airplane around well enough to win 5 NATs and a World Championship with an 11.3" prop. I won the 2006 NATs doing 5 flights in a row with about a 11.75" prop with fuzzy tips, and came in third at the 2000 NATs with about an 11 1/4" prop, again, on a substantially larger airplane of about the same weight.
I wouldn't worry too much about vertical performance, it's a PA75 for goodness sake. You can stick almost anything on there and it's going to work better than anything ever used in stunt before about 1985. David is trading off a bunch of things to *optimize* the system, not just trying to get it to do patterns.
If want to use a 12" prop, go right ahead, but you certainly don't need a 75 to do that, it's like a shaft run. I flew A LOT of flights with 40VF and a 12-3.3 prop. 12" 3-blade, maybe a PA51, and it will be absolutely idling around.
I cannot overemphasize that David's 75 system is intended to basically operate at a near-idle in a deep 4-stroke on the extremely light load of a 13-4 3-blade. First time I flew it, it took off, and I yelled out asking if it was broken, because it was running SO deep in a 4-stroke. He's pumped it up a little bit since then but it still, when right, sounds like couldn't possibly be putting out enough power. The idea is to get it so far away from a 2-stroke that there is almost no chance that it breaks more on outsides than insides -since it never breaks at all.
And it's not about "wobble" in the corners, it's just that larger diameter slows the corner, requiring other trim changes that destabilize it in other parts of the flight.
However, like I said recently in another case, it would be highly advisable to not get too innovative until you have a working baseline system, and use parts that others have managed to get working.
