  • August 03, 2025, 08:11:15 PM
Author Topic: Plane suggestion for an old .19 Torpedo Green Head  (Read 3016 times)
Offline Target
  • C/L Addict
« on: August 03, 2015, 07:04:05 PM »
I have an old .19 Green head I found in storage. I believe that a friend gave it to me long ago.
If I can get it to run well, what would be a good plane, either ARF, ARC or even a kit, to put it in.
I have no idea what amount of power that something like this will make, although I would guess it would be less than a current .15.
It certainly is a "tall" motor for its size. I'd guess it has a long con rod and or a long stroke for the displacement. Maybe it turns a decent diameter prop?
Thanks in advance. :)
Chris
AMA 5956
Re: Plane suggestion for an old .19 Torpedo Green Head
« Reply #1 on: August 03, 2015, 07:07:03 PM »
Yak9
Offline steve bittner
« Reply #2 on: August 03, 2015, 07:14:20 PM »
Ringmaster jr or jr flite streak
Offline De Hill
« Reply #3 on: August 03, 2015, 07:18:08 PM »
Sterling F-51 Mustang.
De Hill
Offline Mike Keville
« Reply #4 on: August 03, 2015, 07:26:09 PM »
Ditto.  (Or the Sterling Yak-9.)
Offline Target
  • C/L Addict
« Reply #5 on: August 03, 2015, 07:38:21 PM »
Wow, that was some seriously fast responses! Thanks guys.
Who sells these kits, if they are kits?
Thanks again.
Chris
AMA 5956
Offline Target
  • C/L Addict
« Reply #6 on: August 03, 2015, 07:40:49 PM »
http://brodak.com/control-line-kits/brodak/old-time-stunt/sterling-f-51-mustang-kit.html
http://brodak.com/control-line-kits/brodak/old-time-stunt/yak-9-kit.html
http://brodak.com/control-line-kits/brodak/trainer/jr-ringmaster-kit.html
Is the .19 a little big for the ringmaster jr wing at 200 squares? I know it says .09-.19, but 200" seems like a small plane, and maybe the engine would be a bit heavy?
Chris
AMA 5956
« Reply #7 on: August 03, 2015, 07:50:37 PM »
Yes, the Torp .19 is way too much power for the Ringmaster Jr.  Forget that one!
Offline Target
  • C/L Addict
« Reply #8 on: August 03, 2015, 07:54:19 PM »
What about a full size S-1 Mike? Will the .19 Torpedo pull it with enough authority?
Chris
AMA 5956
Offline Norm Furutani
« Reply #9 on: August 03, 2015, 08:24:00 PM »
Trade/sell it to a Nos FF guy. It's perfect for a RamRod or a Zeek! Or build a FF, perfect between glider rounds at Perris!
Norm
« Reply #10 on: August 03, 2015, 08:35:31 PM »
Full-size S-1 would work . . . but I like Norm's suggestion better!  :)
Offline Target
  • C/L Addict
« Reply #11 on: August 03, 2015, 08:38:27 PM »
No time to chase escapees between rounds...
Do you have something to trade, Normie?
Chris
AMA 5956
« Reply #12 on: August 03, 2015, 08:56:12 PM »
The K&B 19 Green Head is a reasonably powerful engine.  It's actually one of the most powerful for it's size in the era it was made and used.  Only the Veco 19 rivaled it.  I had a highly reworked one with a different head and piston in the mid 50's  in a Dizzy Boy and it was very fast for the time 7-6 prop on 40% nitro, several runs on 60 ft lines over 135 mph (two lines).  Certainly not a record breaker but respectable in 1957.
I saw a couple flying S1 Ringmasters very respectably also in about the same time frame.  Excellent engine for nostalgia FF as mentioned above.  I was pretty much Combat, Rat Race and Speed in those days so I never actually used one in a stunt type airplane.  The re is however a possibility of a kit being made by Mike Griffin of the Little Thunderbird that it would be perfect for.  I think it's about 475 SQ in.
Offline Target
  • C/L Addict
« Reply #13 on: August 03, 2015, 09:10:27 PM »
Thanks Randy.
I'll get the thing on the test bench with "my mechanic" and see how she runs. I can decide from there.
I'm thinking the full size S-1 might be a good bet if Mike doesn't get the little T bird kit going. He's got lots of irons in the fire!
Thanks again.
« Last Edit: August 03, 2015, 09:52:49 PM by Chris Behm »
Chris
AMA 5956
« Reply #14 on: August 03, 2015, 09:42:30 PM »
. . . I had a highly reworked one with a different head and piston in the mid 50's  in a Dizzy Boy and it was very fast for the time 7-6 prop on 40% nitro . . .
Numbers transposed there?  Probably more like a 6-7 prop, I'd guess.
« Reply #15 on: August 04, 2015, 06:36:38 AM »
The Torp .19GH is perfect for a Flying Fool even though a Flying Fool isn't perfect. it makes a fun combination.
Offline Target
  • C/L Addict
« Reply #16 on: August 04, 2015, 09:54:45 AM »
Thanks Randy.
Chris
AMA 5956
Online bob whitney
« Reply #17 on: August 04, 2015, 12:30:31 PM »
now is the time for the ARF Flight Streak , very lite . 19 dosent need much fuel so short nose wont affect it
rad racer
Offline Target
  • C/L Addict
« Reply #18 on: August 04, 2015, 01:10:28 PM »
I thought the flite streak had issues with the fuse falling apart at the nose? Maybe that's a myth or been fixed, but I swear I read that somewhere....
Chris
AMA 5956
« Reply #19 on: August 04, 2015, 01:13:16 PM »
So, fly it until it falls apart, and then patch it up and fly it some more!
Offline Target
  • C/L Addict
« Reply #20 on: August 04, 2015, 01:51:04 PM »
Even if it takes a little more time, I shoot for durability before putting something in service. How much truth in the breaking nose issue? Anyone know?
Thanks.
Chris
AMA 5956
Offline Garf
    • Hangar Flying
« Reply #21 on: August 04, 2015, 02:26:40 PM »
I broke the nose off mine on the first crash. Nothing about 4 oz. of epoxy can't cure.
Online bob whitney
« Reply #22 on: August 04, 2015, 03:15:28 PM »
 any profile that dosnt have motormounts going past the leading edge of the wing can snap the front off ,even the Ringmaster ,a little glass cloth and epoxy will stiffen it up
rad racer
Offline Target
  • C/L Addict
« Reply #23 on: August 04, 2015, 06:58:11 PM »
Thanks, gents.
I'll consider the Steak, but it'll probably not be my number one pick, just because I hate fixing things that shouldn't need to be.
Chris
AMA 5956
Offline Larry Renger
« Reply #24 on: August 04, 2015, 07:31:26 PM »
Perfect for the RSM .15 size, Ron Burn P-51!
Offline Target
  • C/L Addict
« Reply #25 on: August 04, 2015, 07:33:38 PM »
Yeah, I actually thought about that one also, Larry.
I'll have to take a closer look at yours next time.
Chris
AMA 5956
« Reply #26 on: August 04, 2015, 08:24:22 PM »
OK, T. If there is any pop left in the green head, I have a NIB Thunder Tiger 15. RC, inc muffler I would consider trading. If you're interested, i'll bring it to WN.
Norm
Offline Target
  • C/L Addict
« Reply #27 on: August 04, 2015, 08:35:00 PM »
I think I might just run it on something, but still undecided.
Plus I'm tired of asking DLR to help me with venturi's....
But, you should have seen that magnum boogie. It was impressive!
Chris
AMA 5956
« Reply #28 on: August 04, 2015, 09:08:41 PM »
Yeah, good catch Mike...your post made me go to the shop and dig out some old records from those times...yes believe it or not I used to keep excellent recorda of nearly each flight (especially in Speed) and it said there were a plethora of props tried but the best times were with mofified tornado 7-7 cut and reshaped to 6.1-7.   Hey forgive the error it was 58 years ago.  I have trouble remembering what I had for breakfast today!!!
« Reply #29 on: August 04, 2015, 09:24:12 PM »
No sweat, Randy...I knew what you meant.  Those were the days of REAL Speed events:  Doolings, McCoys, Torps...two lines and no limits on fuel.
« Reply #30 on: August 04, 2015, 11:55:41 PM »
Yeah...a couple of years after that I had a monoline Dizzy Boy with a Dooling 29 that actually set the record in B at 149.6 for all of one day.  Shelton and Harris broke it at 157.2 with an engine they built on a McCoy 29 crankcase.  They used 70% Nitro.  I tried it in the Dooling and broke the crank pin and didn't get an official...sounded like 160 but it only ended up with me holding my beautiful Dooling and feeling like crying.  A lot of groceries bagged and floors scrubbed went into buying that engine!  Rod went through the bottom side of the case and the piston crumbled and stuck in the exhaust port...uhhh the head was OK... HB~>  Comes under the heading of live and learn I guess.  A good friend and mentor Byron Merriweather warned me not to run more than 40% in the Dooling but what the Hexx...I never was one to take good advice!  :'(
Online Robert Zambelli
« Reply #31 on: August 05, 2015, 08:33:19 AM »
VECO Tom-Tom or Tomahawk.
In the 50s, I had both, powered by the K&B 19.
I did everything I could to build them extremely light and it paid off - they really flew well.
Eric Viglione
« Reply #32 on: August 05, 2015, 08:43:27 AM »
Do you plan to run some kind of a muffler? If not, then personally, I'd pass on the profiles, unless your launch assistant likes a lot of noise and castor in the face...   :P
I tortured poor Paul Sequira with my Banshee and GH 35 when I came back to flying C/L back in the late 90's. He was a good sport, but Paul is a rare find in a very good friend. He didn't complain back then, but somehow it came up in conversation years later and we laugh about it to this day.
EricV
Offline Target
  • C/L Addict
« Reply #33 on: August 05, 2015, 09:30:19 AM »
I don't have a muffler for the GH....
Is there one available currently that fits it, or can be made to fit it?
Thanks for bringing up a good point that I overlooked.
R,
Chris
Chris
AMA 5956
« Reply #34 on: August 05, 2015, 11:47:07 AM »
Randy, I wonder how many of us Pappy Meriwether helped back in the day.  Only seen him fly a model once and that was a balloon pop event.   What was funny was after he popped all the balloons some had to go get the handle so he could pull his pants back up.  Thank goodness no one had a camera at the time.  Was very fortunate enough to see him again before he left us.  He knew who you was as soon as I showed him the picture ofyou with your plane.  He supplied me with the McCoy Redhead .60 for carrier I won so many trophies with.  Still have the engine.  So many stories I could relate about him and the boys.
Offline Larrys4227
« Reply #35 on: August 05, 2015, 02:56:18 PM »
EricV
On a profile ... mount the GH on the inboard side.  Exhaust will be facing down and needle up.
Recently did this, and it worked and flew great!
Eric Viglione
« Reply #36 on: August 05, 2015, 03:00:35 PM »
I thought about suggesting that, but then thought about the amount of tip weight it would take to offset all that for a good clean corner, plus whatever doing that does to the over all weight... I guess if it works, it works... depending on his goals for the plane.
EricV
« Reply #37 on: August 06, 2015, 06:39:06 AM »
R,
Chris
Chris - be careful in fitting a muffler to the Green Head 19. We tried one, Tatone as I recall, and the engine tended to overheat.
You might want to try one of the lighter modern mufflers that allow for more expansion. Possibly one from an OS 25 or similar might work.
You'll probably have to fabricate a strap-on adapter.
Offline Target
  • C/L Addict
« Reply #38 on: August 06, 2015, 06:53:41 AM »
Thanks, Robert!
All things considered, Norm might get the trade he wants....
Thanks to all that contributed to my question.
Chris
AMA 5956
Offline frank mccune
« Reply #39 on: August 06, 2015, 07:50:38 AM »
     Hi:
     May I suggest the Brodak Shoestring profile stunter.
        Frank McCune
Offline Target
  • C/L Addict
« Reply #40 on: August 06, 2015, 08:03:38 AM »
Thanks, Frank, I'll have a look at it.
Chris
AMA 5956
« Reply #41 on: August 06, 2015, 11:39:14 AM »
     Hi:
        Frank McCune
That's another great suggestion!
Offline Target
  • C/L Addict
« Reply #42 on: August 07, 2015, 10:56:34 PM »
Has anyone seen a brodak "Cub" fly, or at least seen the plane in person?
Looks interesting.
Chris
AMA 5956
