IMHO....
ARFs are not a bad plane for the money and time. I look at them as a tool to get someone flying quick. And some people are more into flying then the building. What ARFs may do is get someone rebuilding models. Once a person rebuilds a ARF after a mishap they will discover that they can build one.
So they do have a place.
As most people know the first thing you do with an ARF is replace the BC and lead outs. Not a hard thing to to. While you are into the BC have a look around to make sure what you can see in in good order.
And it is always a good idea to iron down the covering and tighten as needed before you fly the plane. And as with any monokote job the covering will come off over time due to fuel getting under the edges. So at some point all monokote planes will have to be recovered.
As for wings coming out of the plane that has nothing to with it being an ARF, and every plane should be pull tested before flying.
Ryan and I have been flying ARF Tutor II's for several years. Mine has been recovered twice and his is currently be recovered. Just due to getting fuel under the edges.
Sitting here counting I have 5 ARFs and all have been recovered, repaired at some point.
No one will every build a plane or anything for that matter that is going to be up to your standards. If you are building or painting your house you will most of the time put in a little better effort. Pull out a bent nail and put in a good nail. A contractor will bend that nail over beat it down into the wood and maybe, just maybe put a good nail next to it without splitting the wood.
ARFs do have a place... but no one does it better then when you build something yourself.
