  • June 22, 2025, 10:56:21 AM
Author Topic: Plane for PA 65 Side Exhaust  (Read 2192 times)
Offline Gene O'Keefe
« on: November 22, 2010, 01:05:18 PM »
Okay - let's say you were lucky enough to get a NIB PA 65 side exhaust---what plane would you put it in ?
Gene O'Keefe
AMA 28386
Offline Steve Fitton
Re: Plane for PA 65 Side Exhaust
« Reply #1 on: November 22, 2010, 01:16:39 PM »
Patternmaster.
« Reply #2 on: November 22, 2010, 03:32:26 PM »
The better question is, what plane can't you put it in.
« Reply #3 on: November 22, 2010, 06:46:21 PM »
Jack Pitcher has one in his "Centennial"...which I've been told is Impact-ish. It runs great, the plane flies great, and Jack flies it great. Oh...it also sounds great, with the Randy Aero CNC tube muffler. So, I'd say an Impact, any of Randy's SV's,  a TP, or a Legacy.  Jack might even have plans for his Centennial available.  I just recalled that Dave Sabon has one in a Shark 45 that is said to be very impressive and tough to beat in the So. Cal. area. Along the same lines, the RSM Hawker Tempest would be a killa klassic entry with the PA .65...it's a restyled Shark. Or the RSM Shoestring, tho it's not klassic legit. The Pathfinder LE would also be wonderful. The Legacy kit is the bargain of the bunch, however.  y1 Steve
« Reply #4 on: November 22, 2010, 07:19:58 PM »
Better question is, "What plane do you want to put it in"???  If I had a shop the size of Kemper Arena I would have all of them. H^^
Offline Mike McHenry
« Reply #5 on: November 23, 2010, 07:26:12 PM »
My Zero  LL~
Offline Ward Van Duzer
« Reply #6 on: November 23, 2010, 07:36:34 PM »
Patternmaster has super fat airfoil designed for the ST .60. Look for a more modern SV wing for the PA
MHO
W-O
« Reply #7 on: November 24, 2010, 04:43:59 AM »
SWEEPER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ;D
Offline builditright
  • So happy to be alive!
« Reply #8 on: November 24, 2010, 08:14:42 AM »
If you're not in a big hurry, give some consideration to my furture kit of the Edge 540 builtup version
Thank you and God Bless
Walter
aka/ builditright
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
« Reply #9 on: November 24, 2010, 01:56:22 PM »
 y1 y1 y1 y1 y1
 Gene
 Aero Products has a lot of designs that the 65 will work  in. I'm flying the SV-11, works great. You might want to look at some of them. (Randyaero@msn.com)  #^ #^ #^ #^
 Gene
« Reply #10 on: November 24, 2010, 04:03:37 PM »
HI Gene,
The great thing about a PA .65 SE is that you can put it into the biggest C/L stunt planes ever designed! LL~
Personally, I couldn't make that decision.  Any of Randy's planes would be good, any of Windy's "Cardinal based" (Patternmaster based??) planes, some Classic planes........  I would probably go with an original SV11 if I wanted it to be a "contest plane".  It was one of the best planes I ever had, and mine only had a ST G.51!
Big Bear
Offline Michael Schmitt
« Reply #11 on: November 28, 2010, 08:39:09 AM »
A Bob Gialdini "Eclipse" y1
« Reply #12 on: November 29, 2010, 10:43:31 PM »
A real possibility in the future!
Big Bear
« Reply #13 on: November 29, 2010, 11:06:49 PM »
Anything..
