  • July 12, 2025, 03:44:21 PM
Author Topic: plane cleaner  (Read 5459 times)
Offline bob whitney
plane cleaner
« on: October 11, 2020, 04:58:48 PM »
what is everyone using to clean glo powered stunters
rad racer
Offline bill bischoff
Re: plane cleaner
« Reply #1 on: October 11, 2020, 05:15:12 PM »
electric motors  ;D
Online Mike Hazel
Re: plane cleaner
« Reply #2 on: October 11, 2020, 05:40:15 PM »
Bob,   I use a 50/50 mix of "Formula 409" and water.  Sometimes I put in a tablespoon or two of methanol in the solution as well.  ZZ
Online Gary Dowler
Re: plane cleaner
« Reply #3 on: October 11, 2020, 06:14:47 PM »
Often I’ve used Windex type glass cleaner, but these days I use the foaming Scrubbing Bubbles cleaner. Works very well
Gary
Offline EricV
Re: plane cleaner
« Reply #5 on: October 11, 2020, 08:09:43 PM »
Bob, I'll give you the best tip I can and it originally came to me from Eddy R. That is to wipe the plane dry of oil as best you can with soft blue shop paper towels BEFORE you spray any cleaner on the plane, otherwise you just push the oil around and it takes twice as much time and work to get it clean. Once you have the plane wiped down, use the cleaner of your choice. I've used everything from windex to concoctions of windex and fantastic, 409, mr clean, etc,  and most worked fine for me, but keep in mind I use Klasskote and urethane clear which is mostly impervious to anything.
EricV
Re: plane cleaner
« Reply #6 on: October 11, 2020, 09:31:34 PM »
   You mean to tell me you guys clean your airplanes? They're just going  to get dirty again!!
Offline John Leidle
Re: plane cleaner
« Reply #7 on: October 11, 2020, 09:57:39 PM »
  I use Windex & sometimes Turtle Wax spray.
  John L.
Offline Curare
Re: plane cleaner
« Reply #8 on: October 11, 2020, 10:49:36 PM »
Original Windex, full strength. NOT the stuff with ammonia. Guess why? And lots of cheap paper towels. y1
Whats the problem with the ammonia?
Greg Kowalski
AUS 36694
Online Dennis Nunes
Re: plane cleaner
« Reply #9 on: October 11, 2020, 11:14:58 PM »
Re: plane cleaner
« Reply #10 on: October 11, 2020, 11:37:20 PM »
Did the price of Sprayway go up? The link you have is for a 6-pack for $35.39. That's almost $6 per can. Just before the NATs I picked up a 2-pack of 19oz. cans for $3.80 at my local Walmart.
Dennis
'   I get it at Safeway, I never noticed how much it cost.
Re: plane cleaner
« Reply #11 on: October 12, 2020, 12:20:45 AM »
On some dope it will bleach it. Happened to me, once. I think Brett B said not to use it  a few years back as well. I do try to heed his advise, even if I don't understand it. LL~
    I don't think that was me, although ammonia might not get along with bare color dope (although fuel is far worse!). I use it because that's what Phil Granderson told me to use, and he's the coolest guy I know.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: plane cleaner
« Reply #12 on: October 12, 2020, 03:42:02 AM »
Windshield washer fluid.  Get winter blend it has more alcohol in the mixture.
 Spike it with a little extra dish soap and alcohol if you have some.  A gallon never fits when I refill the truck and I dump the remainder in a squirt bottle.
Dave Siegler
NE9N extra class
AMA 720731
Offline Peter in Fairfax, VA
Re: plane cleaner
« Reply #13 on: October 12, 2020, 08:25:55 AM »
Offline BillP
Re: plane cleaner
« Reply #14 on: October 12, 2020, 10:15:42 AM »
That's basically what I do in old spray bottles with finger sprayer. Mostly windshield washer fluid, a dab of dish soap and a small amount of ammonia. I do one gal of strong solution for planes and a gal of weak solution for my hands. First learned this way back on ISKY's forum and been using it ever since. I fly all castor at 25%-29% and it cleans up well. It hasn't damaged any brand dope or covering.
Bill P.
Re: plane cleaner
« Reply #15 on: October 12, 2020, 10:34:30 AM »
electric motors  ;D
They don't have enough prop blast to move the oil!
Tom Vieira
Re: plane cleaner
« Reply #17 on: October 12, 2020, 11:32:34 AM »
I was taught to wipe off as much oil as you can with paper towels.  Then when you get home use alcohol and old rags,  Like T-shirts  and flannell shirts that you don't wear any more D>K
Re: plane cleaner
« Reply #18 on: October 12, 2020, 03:53:34 PM »
I just unhook the lines, throw it in the car and hang it on the wall when I get home.  Sometimes there will be a dead bug on the LE. H^^
Ok, on my IC's that I flew now and then, I use shop rags, the red kind, to sop up the slime at the field then Windex and a thin dishtowel before going back on the wall.
« Last Edit: October 13, 2020, 10:43:34 AM by Ken Culbertson »
Re: plane cleaner
« Reply #19 on: October 12, 2020, 04:40:11 PM »
I like "Scrubbing Bubbles", mostly because the spraycan is not going to leak, spill, or make a mess. But it also does a fine job.  y1 Steve
Offline Dave Harmon
Re: plane cleaner
« Reply #20 on: October 13, 2020, 09:24:49 AM »
The type of paper towel makes a huge difference.
Cheap towels just push the oil around....don't soak up the oil and cleaner.
I use VIVA towels to first soak up the oil, then spray with cleaner (I use Windex) and wipe down with VIVA towels again.
Works great with minimum effort.
Re: plane cleaner
« Reply #21 on: October 13, 2020, 10:15:58 AM »
   It does, the cheap kinds are like they are water-repellent.
    I recommend Bounty Select-a-Size.
Re: plane cleaner
« Reply #22 on: October 13, 2020, 12:59:35 PM »
I use Sprayway for windows.  Works great.  For airplanes, some Dawn liquid in warm water works as good as the high-priced stuff.
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: plane cleaner
« Reply #23 on: October 13, 2020, 01:49:25 PM »
Hello Before leaving the flying field I (in fact the whole family cleans the models) usually wipe off as much oil as we can with paper towels, tissues or serviettes that I have in the field boxes. When home I use warm water and dish-washing detergent and an old soft singlet or tea shirt to clean remaining oil left off. This works just as well as window cleaner and if the model is epoxy or urethane coated or a polished finish it cleaners up much better.
 Stack or tongue mufflers make so much more mess and a pipe or well designed muffler make for easier cleanups.
Regards Gerald
Offline Dave Harmon
Re: plane cleaner
« Reply #24 on: October 13, 2020, 05:06:52 PM »
Hopefully they are cheaper than VIVA at $2.25 a roll!!
The industrial towels yank outta da box at Lowes/Home Depot work pretty good too.
Offline Phil Spillman
Re: plane cleaner
« Reply #25 on: October 14, 2020, 10:38:18 AM »
I make up my own mixture : To a gallon of water add 1 ounce of blue dawn. this becomes 1/2 of the plane wash mix. the other is Super Clean in purple can/ bottle cut to a consistency of 3 parts water to 1 part super clean. Mix the tow in a separate jug and pour into your favorite spray bottle. I prefer the one which fits in my big flight box which always stays in my car! I use Viva paper towels to wipe and to wash of the planes after every session. The towels used to wash the plane as opposed to wiping off the oil, can be used again to either wash or wipe as the case may be. Paper towels are good for more than one use!
Phil Spillman
Phil Spillman
Offline Fredvon4
  • Central Texas
Re: plane cleaner
« Reply #26 on: October 15, 2020, 10:27:42 AM »
Some guys need to learn comparison shopping
6 bucks a can for Sprayway is double the cost other places like Amazon
Both links are right here in this thread
Fred von Gortler IV
Re: plane cleaner
« Reply #27 on: October 15, 2020, 10:37:53 AM »
     Sorry for not spending the time to post a link with the cheapest price. I spent the effort to find *a* reference, I wasn't going to spend a lot of time doing comparison shopping for everyone. Next time, I won't post a link, you guys can all go figure it out for yourselves.
  Geez.
Offline Leonard Bourel
Re: plane cleaner
« Reply #28 on: October 15, 2020, 05:59:37 PM »
Hey Brett Thanks for the advice always It is much appreciated when it dosent cost anything and comes from thoes who know I dont really care how much it costs within reason especially if it works Thanks !!!
Offline Lyle Spiegel
Re: plane cleaner
« Reply #29 on: October 18, 2020, 05:18:43 PM »
I have one spray bottle of SIG magic model cleaner remaining. It works great but is hard to find. Label says ingredients are isopropyl alcohol and ammonia. Dies anyone know proportions of these? I have also read that the mixture releases chloroform.  Anyone know for sure?
Lyle Spiegel AMA 19775
Offline bob whitney
Re: plane cleaner
« Reply #30 on: October 18, 2020, 06:02:41 PM »
Sprayaway,$2.09 at wallmart, will let u know how it works next week end,RAD
rad racer
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
Re: plane cleaner
« Reply #31 on: October 18, 2020, 06:50:30 PM »
  y1 y1 y1 y1 y1 y1
 Bob:
 I've Been using glass plus for years 2pts, Glass plus to 1 part water. Works well & cheep.
 Gene
Offline bob whitney
Re: plane cleaner
« Reply #32 on: October 21, 2020, 03:42:27 PM »
tried windex ,409, simple orange and Sprayaway, Sprayaway was the best by Far,RAD
« Last Edit: October 21, 2020, 04:13:01 PM by bob whitney »
rad racer
Offline BillP
Re: plane cleaner
« Reply #33 on: October 21, 2020, 04:19:23 PM »
Corrected from the Glass Cleaner Safety Data Sheet
3. Composition/information on ingredients
Mixtures
Chemical Identity CAS number Content in percent (%)*
Ethanol 64-17-5 1 - <5%
Ethanol, 2-butoxy111-76-2 1 - <5%
Propane 74-98-6 1 - <5%
Butane 106-97-8 1 - <5%
* All concentrations are percent by weight unless ingredient is a gas. Gas concentrations are in percent by volume.
« Last Edit: October 22, 2020, 08:00:49 AM by BillP »
Bill P.
Re: plane cleaner
« Reply #34 on: October 21, 2020, 05:56:41 PM »
Is that the Sprayway All Purpose Cleaner?
No wonder it works so well...
Water 7732-18-5 50 - <100%
etc....
  No. That's why I said Sprayway Glass Cleaner and posted a link to it - so people would know what to look for when they went to buy it at Safeway/Kroger.
Offline Dane Martin
  • heli pilot BHOR
Re: plane cleaner
« Reply #35 on: October 21, 2020, 07:21:52 PM »
All my planes are monokote, so I just use isopropyl alcohol in a spray bottle
Offline bob whitney
Re: plane cleaner
« Reply #36 on: October 21, 2020, 08:46:34 PM »
it is  the glass cleaner
rad racer
Re: plane cleaner
« Reply #37 on: October 22, 2020, 12:08:54 AM »
I just use part of a select a size  bounty towel  and  wipe  the oil of of the  tailwheel  about  every  4 or  5  flights
Re: plane cleaner
« Reply #38 on: October 22, 2020, 06:00:56 AM »
I still contend that the best way to remove exhaust from your plane is to not put any there in the first place!  y1
Offline BillP
Re: plane cleaner
« Reply #39 on: October 22, 2020, 08:02:19 AM »
Got it. Corrected.
Bill P.
Re: plane cleaner
« Reply #40 on: October 22, 2020, 11:18:25 AM »
Before you get frustrated trying to find "Sprayaway",  you might have better luck by spelling it correctly. It is "SPRAYWAY".
Their website is
www.spraywayretail.com
The label states it contains no ammonia
Online Jim Kraft
Re: plane cleaner
« Reply #41 on: October 25, 2020, 12:59:02 PM »
For cleaning castor off the best thing I have found is PB PLASTER. Leaves a nice shine and removes the gunk fast. The smell is not all that great. Worked great though for Fox and McCoy all castor fuel.
When I started flying ignition almost exclusively and using Walmart Super Tech two stroke oil,  I just us a paper towel or an old cloth. Wipes of clean.
Re: plane cleaner
« Reply #42 on: October 31, 2020, 02:21:48 PM »
Hi Friends, Ammonia will tarnish Aluminum Spinners! If you don't car spray on! If you do avoid those products containing ammonia.
Phil Spillman
Phil Spillman
Offline Steve Dwyer
Re: plane cleaner
« Reply #43 on: October 31, 2020, 02:32:36 PM »
I use Windex and paper towels but my planes don't have front row finishes.
Offline BillP
Re: plane cleaner
« Reply #44 on: October 31, 2020, 10:37:12 PM »
Phil Spillman
I think it matters what the concentration is and how long you leave it on.  The mixture I make has maybe 10% ammonia added to windshield washer fluid and it doesn't do anything to al spinners or engines. I spray it on and wipe it off.
Bill P.
Re: plane cleaner
« Reply #45 on: November 01, 2020, 06:16:57 AM »
I just use steel wool and acetone.  I think that Brett recommended that one time.  I think he can recommend a website for it, but gets upset if you start asking him stuff like "can't I get acetone cheaper at Walmart?"  Steel wool is getting harder and harder to find since they came out with scotchbrite pads.  I don't recommend those as they might scratch the paint.
