  • July 01, 2025, 02:55:35 AM
Author Topic: Pictures and Specs of finished Imitation  (Read 818 times)
Offline Mike Griffin
« on: April 17, 2018, 02:18:08 PM »
Ok hope this will answer the questions some of you have asked.  Final weight as you see it in the picture with tank and LA.46 engine mounted is 54 ounces.  The prop is a Thunder Tiger 11 x 4.5.  Center of gravity is 3 1/2 inches back from leading edge but plane tends to be a little tail heavy as you see it.  The engine is a Randy Smith enhanced OS LA.46.  The clear coat is applied and she is ready for a test run.
Offline gene poremba
Re: Pictures and Specs of finished Imitation
« Reply #1 on: April 17, 2018, 05:27:36 PM »
 Very nice work Mike. Hope it flies as well as it looks. I'm looking forward to starting mine......Gene
« Reply #2 on: April 17, 2018, 05:40:35 PM »
Thank you Gene.   Hope to get it in the air in a couple of weeks.
