Ok hope this will answer the questions some of you have asked. Final weight as you see it in the picture with tank and LA.46 engine mounted is 54 ounces. The prop is a Thunder Tiger 11 x 4.5. Center of gravity is 3 1/2 inches back from leading edge but plane tends to be a little tail heavy as you see it. The engine is a Randy Smith enhanced OS LA.46. The clear coat is applied and she is ready for a test run.
