As theyre a development of the olde Wisnewski ' Torpedo ' racing engine , with bigger gudgeon , stronger rod , bigger crank , bearings & gas passage & increased ridgidity
and the transfers a copyish of the ST patented port used in the RATTLER ST / Torpedo 29 hybrid , there should be the potential to ' wake them up ', some .
A decent long tapered veturie intake might do a bit of good , steadying it up .
Ive left the bypass a shade wider than the fin , or havnt gotten around to getting it flush , yet ( may need less noseweight )
There sufficent meat in the side there.
but if I was waking it up ( 160 mph pylon ) might pay to leave it , at the K&B case Rattlers could blow the top off - due to the bypass being hogged out .
The Later the Torpedo , the bigger the bypass passage. Pretty much the same with ST too . Later cases having greater external bypass housing .
Hence the chance to chop some off - inside or outside .
If theyre laxidasical , Id chuck on a 8 x 6 , wind it up / give it grief . After that if it didnt cooperate try 20 or b40 % nitro to see whatitd do , briefly .
20 % and the tourque should swing a 12 x 6 . As the ST 21 / 40 will on NO nitro - unmuffled . Sucks the juice with the effort though .
