  • July 18, 2025, 08:23:46 AM
Author Topic: Scored A New Sig Magnum Still In The Wrapper  (Read 2225 times)
Offline Dick Pacini
« on: June 25, 2012, 01:08:07 PM »
By chance I saw it in the classified ads here on the forum.  I have always been curious about this airplane, so when one cropped up, I was all over it.
Impressive kit.  Foam wing and tail feathers,  nice building manual and decent hardware.  The packing in the box was a 1993 newspaper wadded up, so this puppy is old enough to vote.
So, It took its place in the rack.  Anybody have good stories to tell about it?  Strange that Sig dropped it.
AMA 62221
Offline Balsa Butcher
  • High Desert Flier
Re: Scored A New Sig Magnum Still In The Wrapper
« Reply #1 on: June 25, 2012, 01:22:48 PM »
A number were made and flown here in NorCal, including one by myself. Only tip I might throw in is: the wing is hollow, a little too hollow. One large hollowed cut out. If you use the kit wing cut a foam "spar" and insert it into this hollow to keep the airfoil from flattening out later on down the road.  For rough field use I'd go with CF fuselage mounted landing gear. Engine wise, I'd use good ST G-51 but there are many that would work well. 8)
« Last Edit: June 25, 2012, 02:58:55 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: June 25, 2012, 01:44:36 PM »
Don't put the landing gear in the wing.
  • Gravitywell
« Reply #3 on: June 25, 2012, 06:08:42 PM »
As per proparc....DO NOT PUT THE LANDING GEAR IN THE WING.....and do put in the spar as well.  I both ripped out the landing gear and wrinkled the skin on the wing cause of flexing.  Loved the plane though!
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
steven yampolsky
« Reply #4 on: June 25, 2012, 07:14:33 PM »
I flew a nice Magnum with a Double Star 54. The model was quiet a bit nose heavy so you may want to look at way to mitigate the issue. See if the wing can be moved forward 1/2(more if you are planning to use a heavy motor like ST51).
By the way. Double Star 54 has got to be THE MOST underrated motor. It weights less than 9oz(with TWO ball bearings!) and makes the power of a ST60.
« Reply #5 on: June 26, 2012, 07:09:04 AM »
An easy way to cure nose heavy and to help the plane fly better.  Add three inches to fuse length and move stab/elevator accordingly. H^^
Offline louie klein
« Reply #6 on: June 26, 2012, 08:16:50 AM »
Hi Dick!, Go to builtrightflyright web site and after entering pick "helpful hints" at the bottom. You will find a list and at the bottom is a big build article by Walter himself about the Magnum. EXCELLENT!---LOUIE  D>K
Offline Allan Perret
  • Proverbs
« Reply #7 on: June 26, 2012, 08:54:36 AM »
I had two Magnums with ST-51, great combo.
Others had always told me the stock kits build on the heavy side.
Mine came out 62 and 64oz.
That's not even close to heavy for 700 squares.
I also got one still in the shrink wrap about 4 months ago right here in the classified.
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
« Reply #8 on: June 26, 2012, 08:56:08 AM »
Too bad Tom doesnt have a rear exh version.
Hint Hint.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #9 on: June 26, 2012, 03:59:23 PM »
Instead of using dope or (far worse) monokote to cover the built up flaps, try planking them with 1/32" balsa or 1/64" plywood. You'll be much happier with the result.
Power with an ST .60 if you can find a good one.
Not a good candidate for electric power, I'm thinking. But I've been wrong about such things before.
The Magnum is just a big old sweet flying pussycat of a plane, which goes right where it is pointed. With a larger motor, it will pull your arm out of the socket.
Mike Pratt's excellent design.
L.
"Be wiser than other people if you can; but do not tell them so." -Lord Chesterfield
Offline Ward Van Duzer
« Reply #10 on: July 01, 2012, 09:35:39 AM »
Mikey's MAGNUM Force (top), and Profile FORCE (w/Chip wing) bottom. Magnum was powered by a Piped P.A. .61. The little guy by an OS .32 on a pipe.
Ward
« Reply #11 on: July 01, 2012, 09:45:07 AM »
And the Delta FORCE!
W.
Offline RogerGreene
« Reply #12 on: July 01, 2012, 06:21:42 PM »
Hi Ward,
How well does the Delta FORCE turn?
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
« Reply #13 on: July 02, 2012, 06:53:19 AM »
Sorry, can't answer that. That's Mikey's ship. He knew I was a Force Fan and sent that on to tease me!
W.   ::)
« Reply #14 on: July 02, 2012, 08:00:01 AM »
I remember when he had the Delta Force at a VSC a few years ago.  Have been waiting for plans or details ever since.   H^^
