  • June 19, 2025, 11:16:44 AM
Author Topic: carbon fibre  (Read 1115 times)
Offline Fred Quedenfeld jr
carbon fibre
« on: July 22, 2015, 04:53:41 PM »
where  can I get .014" x .25" pre-cured unidirectional carbon
thanks
Fred Q
Offline Paul Walker
Re: carbon fibre
« Reply #1 on: July 22, 2015, 07:04:48 PM »
Try "DragonPlate". That's where I get most of my CF laminate.
« Last Edit: July 23, 2015, 07:21:10 AM by Paul Walker »
Re: carbon fibre
« Reply #2 on: July 22, 2015, 10:49:03 PM »
Try "DragonPlate". That's where I get mist of my CF laminate.
What does carbon fiber MIST look like... LL~ LL~ LL~
That must be what makes your airplanes so light weight!!!
Congrats on your Nats win!!!
Re: carbon fibre
« Reply #3 on: July 23, 2015, 05:38:16 PM »
Dave Brown Products used to sell that sort of stuff. I've seen CF extrusions (rod and flatbar) in the LHS. Not sure it was K&S, but it was near the K&S rack of tubing, rod, sheet brass, etc. Otherwise, I'd look at CST or Tap Plastics websites and see if they have it.   H^^ Steve
Edit: Dave Brown Products sold everything except the spinners & adapters to Ohio Superstar Products last year. I can't believe they didn't tell me! The CF tape is still available, but apparently not in multiple thicknesses. You start at the end and snap it to the correct width, then keep it going down the length you need. Use CA to glue it, not epoxy, of course.  http://www.ohio-superstar.com/dave-brown-product-line/carbon-fiber-strip
« Last Edit: July 23, 2015, 06:47:43 PM by Steve Helmick »
Offline pmackenzie
  • Pat MacKenzie
Re: carbon fibre
« Reply #4 on: July 25, 2015, 08:33:57 AM »
MAAC 8177
Re: carbon fibre
« Reply #5 on: July 25, 2015, 08:56:52 AM »
If you glue a strip of that down both sides of a profile fuselage it stiffens it tremendously. Rough it up with some 220 grit.
