  • July 19, 2025, 05:47:10 PM
Author Topic: Enya 35 (5224) & 45 (6001) ABC sets  (Read 6742 times)
Offline Brian Gardner
« on: September 10, 2024, 03:46:51 AM »
Hi All,
Just testing the waters so to speak - would there be much interest in me doing ABC piston/liner/rod/pin sets for either the Enya 35 (5224) and Enya (6001)?
Don't get me wrong - I'm still way behind and can't keep up with production of all the current motors...this is more a bit of forward lanning.
Brian
Offline Gordon Tarbell
Re: Enya 35 (5224) & 45 (6001) ABC sets
« Reply #1 on: September 10, 2024, 06:18:32 AM »
Yes and yes
Gordon Tarbell AMA 15019
« Reply #2 on: September 10, 2024, 11:11:05 PM »
Finally ran the FP 40 Liner , in the FSR .40 .
12 heat cycles , then dragged a Magnum thru a breeze . Was shutting off downhill , which a stock FSR wont do .
Early Days yet - but looking good . In the Caudron now .
One needs to relieve the top of the backplate , to clear . Which shows the Timing could go down , dropping the liner .
Havnt Measured to see how much . Recomended for any FSR 40 opperator . The B. G.  FP 40 P/L set up .
45 FSR sets timed at 130 - 110 wouldnt be a bad idea . Theyd fit Magnum GP 44s too , without the piston / trans port .
Only gotta Enya 29 & 45 .
« Reply #3 on: September 11, 2024, 10:12:03 PM »
Dropping the liner would be limited by the piston height vs stroke not stroke and skirt length vs back plate diameter.
« Reply #4 on: September 12, 2024, 01:25:33 AM »
This thread is about whether people want me to make sets for the Enyas. Keep it relevant.
« Last Edit: September 17, 2024, 05:03:52 PM by Brian Gardner »
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #5 on: September 12, 2024, 04:43:07 AM »
Hello We have three Enya 45 6001's on models currently and a 35 ,they are all very good stunt engines from the factory. An ABC set up would probably preform a lot better then the twin ring versions, with less drag and probably run cooler . I would buy a couple of sets.
Thanks Brian for helping keep our old engines running better then ever!
Regards Gerald
Offline Martin Quartim
    • StuntHobby
« Reply #6 on: September 18, 2024, 01:24:58 PM »
I will take one of each. There are 2 Enya 45 6001, the plain bearing Iron P/L and the 45 BB 6001 with Aluminum Piston Ring. The block seems to be the same but I am not sure if the P/L have the same fit for both.
What I really want is an ABC set for my Enya SS50.
Martin
« Reply #7 on: September 18, 2024, 06:13:30 PM »
Hi Martin,  I have added you to the list. The 45 that I am using for sample/measurement purposes is a 6001 45BB twin ball bearing. I don't have a plain bearing version to compare compatibility.
For any engine/new project I need sufficient orders to do a production run of more than 20 units. So I can't help you with the SS50 at this point sorry.
Martin
Offline Philip THOMAS
« Reply #8 on: September 30, 2024, 08:54:35 PM »
Hell yeah.
I’ll take two sets for the Enya 35; one I’ll wear around my neck as jewellery and the other I’ll fly.
« Reply #9 on: October 01, 2024, 02:54:24 AM »
Brian
Hell yeah.
