General control line discussion => Open Forum => Topic started by: john e. holliday on December 02, 2013, 07:59:05 AM
Hey fellows and ladies, check out the following item on the bay if it doesn't get pulled. Item 331078354274. No it is not mine and I know better if you look close. Maybe it is the new super stunt. LL~ LL~ LL~
Fox made a few of these special for people that needed a lot of out-thrust, but still wanted effective cooling. This is the version for inverted use, or for an upright engine on a clockwise plane.
I thought you knew!
Wonder if it even turns over like that?
That's to improve line tension when you don't have enough offset in the rudder, its also reported to minimize the burp on a profile ! <=
So, the head is machined differently? Looks like it's on there crooked. LOL!!!
Jim Hayes
I've bought several engines with heads rotated like that on the bay including a very nice Super Cyclone recently. Since the modeller who owned the motor would never do this I have figured its the goofball selling the estates trying to put a box of parts back together for sale. Those I've got this way have all turned out OK though.
It WILL run in that condition. Believe me. You can rorate the head in any of the six possible positions and the thing will still run. The baffle on the piston will not hit the head.
Bigiron
I saw this one on Ebay a few years ago and, as the only bidder, for $10 it was mine. Stripped it and cleaned off the brushed on enamel paint. On the test stand it started first flick and ran as well as my other 40 VF's :). I'm guessing that even if the seller had tried to run it then he never got it to start considering the little dot of insulating paint on top of the glow plug post.
Really? I wondered about that. It's surprising how many you see like that, so I knew they would turn over.
I guess mine were of a different breed. If I didn't get the head lined up with the baffle I could not turn it through.
