  • July 08, 2025, 12:48:26 AM
Author Topic: Pegasus stunter  (Read 978 times)
Offline Bootlegger
Pegasus stunter
« on: February 26, 2015, 07:46:47 AM »
 Mornin Guy's, I am looking for a copy of the Flying Models article of the construction on this  model.
  Thanks a lot... H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Pegasus stunter
« Reply #1 on: February 26, 2015, 07:58:07 AM »
Hi Gil,
Have you contacted Tom Dixon?  He doesn't use a computer but you can call him or write him.  I've always found him to be very helpful in matters like these.
BIG Bear
RNMM/AMM
Offline bob whitney
Re: Pegasus stunter
« Reply #2 on: February 26, 2015, 09:26:07 AM »
 who's design is it
rad racer
Re: Pegasus stunter
« Reply #3 on: February 26, 2015, 10:52:56 AM »
Is this the twin boom design?  If so do a search for Pegasus and look for the post by Mike Griffith.
Re: Pegasus stunter
« Reply #4 on: February 26, 2015, 10:58:54 AM »
Pretty sure Gil is talking about Bob Howard's '68-'69 Model. Tom Dixon did a build article with corrections from the original FM article.  I have seen Tom fly his a few times and it is a very, very good plane!
BIG Bear
RNMM/AMM
Offline Bootlegger
Re: Pegasus stunter
« Reply #5 on: February 26, 2015, 11:08:07 AM »
 Failed to say that this is the Bob Howard design.. Z@@ZZZ Z@@ZZZ Z@@ZZZ
Gil Causey
AMA# 6964
Offline Gordon Van Tighem
Re: Pegasus stunter
« Reply #6 on: February 26, 2015, 01:32:21 PM »
Here you go!
Gord VT
MAAC 3738L, Life Member
AMA C3738L
Offline Bootlegger
Re: Pegasus stunter
« Reply #7 on: February 27, 2015, 12:28:37 PM »
 Gordon,thanks a lot for that info... H^^
Gil Causey
AMA# 6964
Offline Bill Hummel
Re: Pegasus stunter
« Reply #8 on: February 27, 2015, 02:46:20 PM »
Guys, just a caution on both the original plans and the later Dixon version;  the fuse top view and side views do not match.  Notice where the
stab/elevator are located on the top view...different from the side view.  I'm told that the side view is correct for the design, regardless of which
version you are building.  By the way, built one, DS 40 engine, flew great!  Really worth the build, in my opinion...
ama 72090
