  • July 13, 2025, 07:48:34 PM
Author Topic: Pavement Repair at Whittier Narrows  (Read 2600 times)
Offline Paul Wescott
« on: December 08, 2015, 01:12:11 PM »
I visited Whittier Narrows today and took a few pictures of the pavement repair progress on the CL Stunt Circles.  There are/were 4 guys out there with all the right tools (I think).  Take a look.  Either of the two links below should go to the same place where I put the photo album in Flickr.
THANK YOU JIM LALLY!
Paul W.
https://flic.kr/s/aHskqGRqYN
https://www.flickr.com/photos/star-paul-star/albums/72157662115624486
Re: Pavement Repair at Whittier Narrows
« Reply #1 on: December 08, 2015, 01:34:57 PM »
  Where they are fixing it looks good. But I would suggest that it get scrubbed absolutely clean with a street sweeper and water, or very tediously, with a leaf blower, then completely sealed. I was pretty shocked at the degree to which the sand and small gravel was coming loose when I went down there earlier in the year. The 40+ years of castor oil over on the east/"tree" side of the circles where you take off tended to glue it together, but anywhere else it was like a sandbox.  I didn't find the cracks all that problematic, partly because they had been repaired to some degree over the years.
   All that said, it's one of the nicer public sites I have been too, and the basin is lucky to have this and Sepulveda to fly. At least until model airplanes are outlawed in LA and Riverside counties due to the drone crisis...
« Last Edit: December 12, 2015, 07:12:42 PM by Brett Buck »
Offline aba183210
« Reply #2 on: December 12, 2015, 06:41:45 PM »
I flew there this morning. I noted that the cracks have already been covered with asphalt. There is yellow tape only at the east edge of the field (by the benches).
Online Paul Walker
« Reply #3 on: December 12, 2015, 07:03:03 PM »
Wow, how time flies. I used to fly there before thare was an asphalt pad. Had to dodge the gopher holes.
Glad they are maintaining it for those who still use it. I would like to fly there again before it is too late.
Offline aba183210
« Reply #4 on: January 09, 2016, 06:47:24 PM »
I went to fly there today. The new pamement is there but the circles are not yet painted.
« Last Edit: January 09, 2016, 07:15:15 PM by aba183210 »
Offline Tony Drago
« Reply #5 on: January 09, 2016, 07:41:07 PM »
I remember when the city of Long Beach, CA. Passed an ordinance to Ban all gas powered model air planes because some one got hurt flying one. I believe they got zapped flying to close to power lines. Long Beach had Hobby Shops ( some really good ones ) all over that city. Some tried to relocate to no avail. It didn't take long for all of them to close their doors. A few hung on, but it was just a matter of time.
« Reply #6 on: January 09, 2016, 08:59:38 PM »
   Is it new pavement or was it just repaired and sealed?   At any rate, sealing it was what it needed the most, because the surface was turning to gravel and sand.
« Reply #7 on: January 13, 2016, 11:01:18 PM »
Cracks filled and surface sealed I think one edge was repaved, Brett.
Chris...
« Reply #8 on: January 14, 2016, 09:36:14 AM »
For the most part, the cracks were "dug out" and enlarged slightly so that they could be filled in (see the pictures).  Then a surface coat was applied.  After some small amount of drying/curing time John Wright found an area that had flaked off as if they had applied the material over a puddle.  Jim Lally has already inspected the crack repair, found it lacking, marked the deficient areas with some type of bright yellow material, and contacted his connection to discuss.  The park management has agreed that a flawed repair is almost no better than NO repair and they will have the crew return to really fix the cracks and any flaked off areas.  Time will tell, we shall see.
Also the edges of the asphalt had been damaged by vehicles (private cars AND park dept. trucks) hitting the edges when they drove up onto the flight surface and breaking the edges off.  The repair crew seemed to do a very good job of rebuilding new edges and not just trimming off the damage.   The park people have agreed to lock the South vehicle gate permanently (I wonder how the Tether Car guys are going to feel about that) in order to keep people (the Speed Guys mostly) from driving in through the South gate and up onto the asphalt, across the stunt/racing circles, over to the speed CAGE (yes cage) and off the far side of the asphalt.  Why do they make that drive?  So they don't have to navigate through a few trees.  The only gate that will be open will be the "Central" gate or East gate which is nearest the North-East corner of the flight surface.  The speed guys will be able to enter the East gate and drive straight West 100 yards to their parking area (no trees to navigate).  Us Stunt guys, if we really REALLY have to drive on the grass real close to the circles, will be able to enter the East gate, drive 100 yards South and navigate the trees.  Either route will not require driving on the asphalt.  Also Larry R. has a plan to post a sign at the corner of the asphalt nearest the East Gate that says "Do NOT Drive on the Asphalt!"   That might work if we add "Video Recording in Progress" and mount a solar powered web-cam in a nearby tree.
Now if only we can convince the R/C Pylon Racers to stop driving ALL OVER THE PLACE including our circles when they set up the pylons.  Doesn't anybody WALK anywhere any more???
Also it was brought up at the last meeting that a few years ago Chuck Rudner (Combat flyer) paid for sprinklers/irrigation to be installed in the grassy combat area.  Then last year the park rented out the ENTIRE PARK for an outdoor rave.  We were promised up and down and sideways (by the promoter) that the entire area would be in better condition after the event than before.  Right.  The trucks that drove all over "gopher gulch" as Mike Alurac calls it, broke the sprinkler pipes in several places and now the grass is read or dying.  There are no known plans to repair the donated sprinkler system for the combat guys.
That's the 2-cent update.
Paul W.
