  • July 18, 2025, 02:04:48 AM
Author Topic: Root and Tip Chord Measurement  (Read 914 times)
Mike Griffin
« on: April 19, 2013, 09:38:46 PM »
On a flapped stunter, do you take into account the width of the flap at the root and the width of the flap at the tip in total root and tip chord measurement?  For example if the root chord of the wing from the leading edge of the wing to the trailing edge is 10" and the flap measures 2" at the inboard end, is the total root chord 12"  and if the tip chord of the wing measure 7" and the width of the flap at the tip is 1", is the total tip chord measurement 8 inches?
Thank you
Re: Root and Tip Chord Measurement
« Reply #1 on: April 19, 2013, 09:55:40 PM »
Thank you
Yes.  If your trying to determine the area of the wing, The flaps are part of the wing
Mike Griffin
« Reply #2 on: April 19, 2013, 09:58:41 PM »
Thank you Randy.  I was not sure about that...
Online Howard Rush
« Reply #3 on: April 20, 2013, 12:28:08 PM »
For why, see the same topic on SSW.
« Reply #4 on: April 21, 2013, 07:28:35 AM »
Howard, some people don't go to the other forums.
Mike Griffin
« Reply #5 on: April 21, 2013, 09:10:09 AM »
Hi Doc
I spend 99% of my time on this forum but i did post this question on SSW also and Howard did give me a good and detailed answer over there.  I usually only post here on Sparky's forum but sometimes I do post over there.
Online Howard Rush
« Reply #6 on: April 21, 2013, 12:58:26 PM »
So what's keeping you from going to the effort to explain it here?
« Reply #7 on: April 22, 2013, 05:43:28 AM »
How could I explain it there if I don't go there??    Oh I guess I do go there once in a while, but you won't see many posts from me there.
