  • July 16, 2025, 07:19:27 PM
Author Topic: Monkeys and stunt  (Read 1915 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
Monkeys and stunt
« on: September 05, 2010, 03:31:04 PM »
Start with a cage containing five monkeys.
Inside the cage, hang a banana on a string and place a set of stairs under
it. Before long, a monkey will go to the stairs and start to climb towards the
banana.
As soon as he touches the stairs, spray all the other
monkeys with cold water. After a while another monkey makes the attempt with
same result, all the other monkeys are sprayed with cold water. Pretty soon when
another Monkey tries to climb the stairs, the other monkeys will try to prevent it.
Now, put the cold water away. Remove one monkey from
the cage and replace it with a new one. The new monkey sees the banana and wants
to climb the stairs.
To his shock, all of the other monkeys beat the snot
out of him. After another attempt and attack, he knows that if he tries to climb
the stairs he will be assaulted.
Next, remove another of the original five monkeys
The newcomer goes to the stairs and is attacked. The
previous newcomer takes part in the punishment with enthusiasm.
Likewise, replace a third original monkey with a new
one, then a fourth, then the fifth. Every time the newest monkey takes to the
stairs he is attacked.
Most of the monkeys that are beating him up have no
idea why they were not permitted to climb the stairs OR even why they are
participating in the beating of the newest monkey. Finally, after replacing
all of the original monkeys, none of the remaining monkeys have ever been
sprayed with cold water. Nevertheless, no monkey ever again approaches the
stairs to try for the banana.
Why not?
Because as far as they know, that is the way it has always
been done.  ;D
Offline David Hoover
Re: Monkeys and stunt
« Reply #1 on: September 05, 2010, 04:04:26 PM »
Marvelous parable, Bob!
Best, Hoovie
Offline Martin Quartim
    • StuntHobby
« Reply #2 on: September 05, 2010, 04:10:21 PM »
I can relate  that to when some one new comes up with a bright new idea to use in C/L  LL~ LL~ LL~ LL~ LL~
Martin
Offline Phil Coopy
« Reply #3 on: September 05, 2010, 06:18:43 PM »
At first I thought it was a comment on congress...... n~.
Phil
Offline Roger Vizioli
  • CLiner
« Reply #4 on: September 05, 2010, 06:23:31 PM »
Phil
Phil,
I know Bob.
Maybe it is!   LL~
Hard to deny!
roger v.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Bob Reeves
« Reply #5 on: September 05, 2010, 06:51:43 PM »
Phil
It originally was  ;)
Offline Dick Byron
  • Vendor
« Reply #6 on: September 05, 2010, 07:19:51 PM »
That is quite good. I does explain the house and senate.
« Reply #7 on: September 05, 2010, 07:48:23 PM »
So....... how exactly does this cute monkey story relate to stunt? Is it perhaps another backhanded assult on the BOM?
Offline Scott B. Riese
  • Just a student of stunt
« Reply #8 on: September 05, 2010, 08:04:40 PM »
OH...........???? MAYBE.....? DK^ DK^ DK^
Scott Riese
Portland, Oregon
AMA 528301
Offline W.D. Roland
« Reply #9 on: September 05, 2010, 08:32:20 PM »
At times like these we must remember we are more like monkeys than like God. n~
Bob
I have like this parable since the first time I heard it. Fits a lot of Human organizations.
This is why we must thoroughly clean house.
I can see November from my porch. y1
David
David Roland
51336
« Reply #10 on: September 06, 2010, 06:24:49 AM »
Phil
A congress there a congress here...........what's the difference LL~ LL~ LL~
