  • July 19, 2025, 08:17:12 PM
Author Topic: Pathfinder ARF ??  (Read 1673 times)
Offline Vincent Corwell
Pathfinder ARF ??
« on: September 19, 2007, 03:49:38 PM »
Thinking of a Pathfinder ARF for my ST51 motor
Any thoughts of how suitable a combination this is please ?
thanks in advance
Vincent
Offline peabody
Re: Pathfinder ARF ??
« Reply #1 on: September 19, 2007, 06:35:43 PM »
Hi Vince....
I believe that the Pathfinder is a great flying ARF and that it can be assembled with the minimum of modifications.
Most around here are powered by either OS 40s or 46s. I know that the ST would haul it well, and could be propped to the right speed. The only shortcoming might be the weight....mayhaps a tube muffler and moving the tank back a bit?
I think you ought to try it!
Offline John Miller
« Reply #2 on: September 19, 2007, 07:06:33 PM »
You'll enjoy the Pathfinder. The engine you're considering is a good one, with gobs of power. I believe it's more power than is needed, but you can always adjust with needle and props.
The plane was designed for a .40, and flies well with any modern one. Some find the LA.46 to be a good fit. Still use what you like, as long as the weight stays within reason, it'll do well.
steven yampolsky
« Reply #3 on: September 19, 2007, 07:50:31 PM »
The only mods I made are the elevator pushrod and regular hinges.
I think ST51 would be absolutely fine if you use lightweigh muffler(Not a stock one). Randy Smith makes very light tube mufflers. Tongue mufflers are fine too.
My ARF flies VERY well on TT 46 Pro. ST51 should be even better!
« Reply #4 on: September 20, 2007, 01:06:52 AM »
Many thanks, friends
I have both the tongue and tube mufflers
will post pics when all is done
Vincent
