  • July 05, 2025, 02:54:53 AM
Author Topic: Patern Bat revisited  (Read 1212 times)
Offline Steven Kientz
« on: April 17, 2008, 05:37:38 PM »
I need some ideas on a fuel tank for this plane. The center of the wing is wide open. I thought about a Sullivan 2oz round with the tubes sticking thru the LE sheeting. A club member suggested a wedge inside the wing. the other suggestion was to cut off part of the sheeting ,add a false rib and make a compartment for a small tank. Any suggestions? i plan on mounting a TT GP25 for power.
Steve Kientz
AMA 855912
Offline ray copeland
Re: Patern Bat revisited
« Reply #1 on: April 17, 2008, 08:08:22 PM »
Would love to see a picture of the completed plane!
Offline Jim Oliver
« Reply #2 on: April 18, 2008, 11:09:04 AM »
Anything like the Aerobat from Model Airplane News---maybe 50 years ago??
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #3 on: April 18, 2008, 04:10:42 PM »
If you look in combat under "converted pattern bat" there is a picture of it so far. I have to get a tank in it before I can go any farther.
Steve Kientz
AMA 855912
« Reply #4 on: April 19, 2008, 10:35:49 AM »
Make you a home made wedge tank to fit between the spars.  I did that with all the VooDoo's I ever built.  If you are running pressure you can put a Vienna Sausage can in behind the leading edge for a pacifier.  bladder tanks require a tube in between the leading adge and the spars.  DOC Holliday
« Reply #5 on: April 19, 2008, 12:24:52 PM »
Made the decision this morning to box the spar(center of wing) and cut the Le out and box in a space for the tank. Probably not the best solution,but this plane has sat for at least 5 years before I got it. I figure some of the glue joints aren't good anymore. I plan on cloth and epoxy for the tank cutout. Hopefully I haven't ruined it.
Steve Kientz
AMA 855912
