  • June 26, 2025, 07:35:35 AM
Author Topic: blank  (Read 1216 times)
Online Motorman
blank
« on: June 07, 2013, 02:38:13 PM »
blank
« Last Edit: September 08, 2021, 05:54:12 AM by Motorman »
Offline Dick Pacini
Re: Partial Kit (Vector 40)
« Reply #1 on: June 07, 2013, 02:43:21 PM »
Contact Brodak and see if you can buy just what you need.
AMA 62221
« Reply #2 on: June 07, 2013, 02:49:57 PM »
I've got a ARF Vector 40 wing and flaps only. I've never made a built up fuselage before so I'm needing that part of the kit or maybe plans. I've thought about just making a profile fuselage that I'm familiar with but, would prefer the kit so I can see how a built up fuselage is made. If it comes to it I guess I could buy a whole kit and copy the fuselage parts but that's a bigger project than I need right now. Anyone want to loan me their Vector kit for a couple of days?
Is there an on line resource that shows the typical construction of a built up fuselage on a modern stunt ship?
I have all the plans parts etc  since I designed the ship. IF I can help let me know
www.aeroproduct.net
Offline Jeff Traxler
  • T-Bone
« Reply #3 on: June 07, 2013, 03:39:12 PM »
I'm going to Brodak with a V4o kit I am going to sell cheap.I need the gas money to get home y1 y1
« Reply #4 on: June 07, 2013, 05:14:19 PM »
MM    I guess you do not look around the forum much. Here is just what you asked for.
http://stunthanger.com/smf/index.php?topic=29657.0
You still need plans so call Randy.
« Reply #5 on: June 07, 2013, 09:26:13 PM »
Well...that is a very instructive build.  However that is rather complex build for a top competition airplane by a very top competitor.
Might be a little complex and intricate for a first built up model.
While somewhat similar, of course, the construction for the Vector is very much simpler.
Contact Randy Smith.
« Reply #6 on: June 08, 2013, 12:36:00 AM »
Thanks for the link, it gives me some basic info I can use. That build didn't have the LG on the fuselage. I guess it's a couple of formers off the motor mounts to a ply pad to mount the LG? The bottom can be a flat sheet 1/8th, 3/16ths?
Yes it can be a flat sheet mounted to the bottom of the fuselage sides.  1/8 birch aircraft grade plywood is adequate.   The plate should be reinforced with triangular strips at the inside of the fuselage to increase the gluing area, and I would only use epoxy for the joints.
If an aluminum gear is used it can be bolted to the plate with 4-40 screws into blind nuts inserted into the back of the plate.  Three screws are adequate, two near the front of the gear and one centered near the back.   This also makes the gear removable.   Mounting a wire gear that way is a little more complex.
Do you plan to use an aluminum or a wire gear?
