  • July 17, 2025, 12:25:18 PM
Author Topic: Panel Lines- Sparky's Super Marine  (Read 1938 times)
Offline Richard Grogan
« on: August 17, 2006, 10:39:52 PM »
Robert, Looking back at you Nats entry pix, are the panel lines silver? What did you use? Gorgeous!!
Long Live the CL Crowd!
                  AMA 85745
Offline W.D. Roland
Re: Panel Lines- Sparky's Super Marine
« Reply #1 on: August 17, 2006, 11:19:56 PM »
I still say them floats is to small
and i still say fantastic airplane!
David
David Roland
51336
Online RC Storick
« Reply #2 on: August 18, 2006, 07:09:13 AM »
Pannel lines are done with Ripdeiograph pens. The lines are black. As are these too.
Offline Phil Coopy
« Reply #3 on: August 18, 2006, 02:54:19 PM »
Robert,
What do you use in the pens...will India ink work.  I have a set left over from "in the day".
Phil
Online RC Storick
« Reply #4 on: August 18, 2006, 04:29:57 PM »
You must use inda ink for film.
« Reply #5 on: August 18, 2006, 04:44:42 PM »
Is it fuel proof on film, or do you have to treat it with clearcote? ???
                  AMA 85745
Online RC Storick
« Reply #6 on: August 18, 2006, 04:46:56 PM »
You must use clear over all panel lines if you want them to last any length of time. and with film ink if you want it to last more than a minute.
« Reply #7 on: August 18, 2006, 04:55:50 PM »
Did you use dope or automotive paints on these birds?
                  AMA 85745
Online RC Storick
« Reply #8 on: August 18, 2006, 05:05:42 PM »
Urethane but dope will work OK.
« Reply #9 on: August 18, 2006, 05:48:47 PM »
Thanks for your patience and info! I ordered a pen set and I'm going to try my hand at it with the vector after I paint it. Probably need to practice on something before I give it a go, though...RG
 y1
                  AMA 85745
Online RC Storick
« Reply #10 on: August 18, 2006, 05:51:30 PM »
Make sure you use a cork back ruler. That elevates the metal off the surface you are inking.
« Reply #11 on: August 18, 2006, 06:00:30 PM »
Thanks. I have a 12 and 24" ss ruler thats cork-backed. Is there a cure time for the ink before you clear cote? How long do you wait before you lay the ruler on fresh ink for the next intersection line without getting a smear? Or is it pretty much instant dry...
                  AMA 85745
Online RC Storick
« Reply #12 on: August 18, 2006, 06:01:30 PM »
Drys pretty quic. I wait a day to clear.
