  • June 19, 2025, 07:39:00 AM
Author Topic: Bob Gialdini's Eclipse  (Read 3142 times)
Offline Brad Smith
« on: March 11, 2012, 09:20:06 PM »
Anybody have any pics of this plane or know where i can get plans?
Brad smith AMA780054
Re: Bob Gialdini's Eclipse
« Reply #1 on: March 11, 2012, 09:39:26 PM »
 Here is Mike Schmidt's more recent rendition, from the Chicago area gang...
Mike Griffin
« Reply #2 on: March 11, 2012, 09:56:03 PM »
Brad Mike may have the plans ..you can also try Allen Brickhaus.....
Offline Shultzie
« Reply #3 on: March 11, 2012, 10:00:12 PM »
Can't help myself....gotta post this great IN FLIGHT SHOT!
(Wonder how this beautiful model with look with a wing mounted gear instead of that scary forward tilted Nose wheel pant that looks OHHHSO CLOSE TO THE PROP?
Take a look at Bob's original Eclipse..and the nose gear position looks  (at least to me) looks so much better.
Hey Brad..
type Bob Gialdini- and Eclipse into the stunthanger search engine at the top of the forum posts... and  check out Les McDonalds amazingly beautiful shots that he took of both Bob's Sting Ray and Eclipse during Gialdini's stop over years ago.
www.stunthanger.com/smf/index.php?topic=12055.msg105929#msg105929
« Last Edit: March 12, 2012, 11:15:14 AM by Shultzie »
Don Shultz
Offline James Mills
« Reply #4 on: March 11, 2012, 10:14:20 PM »
I think Mike and Allen had the plans published last year (Model Aviation?).
James
AMA 491167
Offline Brad Smith
« Reply #5 on: March 12, 2012, 01:11:17 PM »
I found the plans in Model Aviation they are $32 seems a bit high to me though.
« Reply #6 on: March 12, 2012, 02:01:28 PM »
I hear you, Brad.  When I can get a set of plans run off for less than $5, $32 sounds like way too much.  Of course the magazine has to pay for the drafting and article.......... but $32 still sounds a good bit too high. ???
(of course I remember Hobby Helpers plans for less than $1! LL~ LL~ LL~ )
BIG Bear
RNMM/AMM
Offline Shultzie
« Reply #7 on: March 12, 2012, 03:14:59 PM »
A couple more of Les McD's scans from his slide collection. Although they have faded...still beautiful photos of a beautiful Classic model.
Don Shultz
Offline Michael Schmitt
« Reply #8 on: March 13, 2012, 08:07:44 PM »
Bob Did not have any plans for the Eclipse.
Allen Brickhaus did the pencil drawing from the original Eclipse, Watt Moore did a great job working with Allen and I cadding the plans. We all  worked very hard on the plans until they were right. They are full size and the Eclipse is a big airplane. We get no profit from AMA's  sale of the plans but we wanted them as good as we could get them. So others could build and enjoy the Eclipse. Besides 35 bucks is nothing compared to cost of building and finishing a model. When I was at the NATS last year I went over to the plans services at the museum to check them out. They turned out very nice.
As far as the gear goes I used a larger engine than Bob, PA65 compared to a 45. I swing a much larger prop 13 x4 Bolly. In order to get the ground clearance I needed, the gear had to be longer, as a result the main gear shot forward and the nose gear shot backwards reducing the landing gear footprint. I also went with 5/32 gear wire because the 1/8 inch gear wire was insufficient. Not to worry the gear works well and the clearance with the prop has not been an issue during the past two years of competition. I fly off of grass field at old Neddy here in the Chicago area and Beefy gear is what I wanted.  Some have suggested I shorten the prop diameter and up the pitch so I can use shorter gear. My gear is interchangable and it can be done with out harming the airplane. But I wanted to use a a powerplant and prop combo I know would work ---and it did. Any questions send me an e-mail
Offline James Mills
« Reply #9 on: March 13, 2012, 09:28:13 PM »
Mike,
I liked the look, I just have too many irons in the fire now trying to get something for both me and Ben in the air (maybe someday).  I do think it's time for you to retire this one and maybe fly a Ringmaster Jr. in classic (seems I keep seeing the back of your plane come trophy time ;D).  Seriously, nice bird.  Did you see where our guys finally picked up a wide receiver #^?
James
AMA 491167
